Go to Post Border Guard: "Anything to declare?" Team: "Oh, just these trophies!" - dtengineering [more]
Unread 30-08-2012, 15:25
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Re: Ground clearance
Originally Posted by Adrian Clark View Post
Not necessarily, even if the CG is perfectly centered the robot will always be resting on either set of four wheels. I'm not too sure I understand your logic here, why would the robot not be able to turn in place in your given scenario?
I think what he was trying to say is that when turning we (The RoboBees) were always on the same set of wheels. We knew exactly what axis the robot would turn about.
However, if the CG of the robot is close enough to center that enables the teetering you know longer have this luxury. The acceleration at the beginning of the turn and throughout could switch which axis you rotate about. Meaning it could be between the front and center wheels, or the rear and center wheels. We knew that every turn would be about a central point with almost no variation.
It is like have a 4WD robot with a wheelie bar with powered wheels.
Again, the application should drive the design. This is just another option to keep in mind.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 30-08-2012, 15:33
AdamHeard's Avatar
Lead Mentor
This different method of raising a wheel results in the exact same setup as a regular 6wd. You still have two 4wd bases, and the cg location (+ accleration) determines rock.
Unread 30-08-2012, 15:40
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
I might be misunderstanding the conversation, but I'm pretty sure your teammate was talking about supernerds(op) drivetrain. But as for your design, if I understand it correctly, having the CG in the back of the robot is critical since your drivetrain is designed to not teter-totter and be able to interact with the field in ways a standard 6wd drop center can't. I commend you for trying something different, I think your drivetrain has pros and cons when compared to a traditional 6wd drop center, and I love that you were able to boost your ability to traverse field elements with out the standard approach of just making your wheels bigger.
Unread 30-08-2012, 15:45
tim-tim's Avatar
AKA: Tim Miedzinski
Except that we didn't have the rock due to the location of our CG. The only times we used the front wheels (raised front) were to start the process of crossing the bump and when entering/exiting the ramp.
But I understand what you are saying though. But why would you want a robot with a CG + acceleration that would allow rocking in normal situations? Is there too much variance in when it does or does not teeter to be able to predict what axis the robot will turn about?
We chose this design for stability reasons. We always sit on our rear wheels. Likewise we always turned about the same point.
I guess it is just design intent.
The RoboBees
Unread 30-08-2012, 15:48
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
The raised front creates a single 4wd base (for most play) with the ability to traverse obstacles with the front wheels. When in full reverse, there is potential for the acceleration to cause a shift to the [robot] front wheels.
That is correct
Again, thanks for the info on tetering as a method of control. Definitely a new bit of info for me. Ever since stack attack, I've been wary of tippy robots :lol:
OP, I hope we haven't gotten too far off your original question...
Unread 30-08-2012, 16:13
AdamHeard's Avatar
Lead Mentor
I'm saying the reason you didn't rock has nothing to do with your different wheel configuration, and everything to do with CG. Your drive is pretty much a drop center 6wd. You still have two 4wd bases, but primarily drive one one. This is true for most 6wd's. We bias weight on all of ours to get a more consistent turning center.
I'm not saying your decision was a bad one, we did the same thing in 2009; Just clarifying for the lesser informed people reading that there isn't some holy grail difference here.
Unread 30-08-2012, 16:29
tim-tim's Avatar
AKA: Tim Miedzinski
Yes I agree, there is no holy grail answer.
Can I pose the question: if you know are going (significantly) bias the CG to one side of the robot, why drop the center as opposed to raising the front? Not trying to argue the poi t just want a different designers perspective.
The RoboBees
Unread 30-08-2012, 16:39
AdamHeard's Avatar
Lead Mentor
Partly because even with a CG bias, you won't ever prevent the robot from rocking onto those other wheels (a 14-15" wheelbase just isn't very stable for any fast robot).
A bigger factor for us is we don't like giving up symmetry on our parts. If we can maintain it, it makes fab and assembly easier/less confusing.
It's a really trivial difference though, between implementations.
Unread 30-08-2012, 16:47
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
I would strongly caution about going less than 0.5" of ground clearance, here is why:
In 2008, it was a flat game in the rules.... except for th 5" plates supporting the poles for the center divider. That a lot of teams got stuf on.
2010 was flat between the bumps, except it wasn't as they added some plywood at teh entrance/exit ramp surface of the bumps so that teams didn't damage the flooring.
2005 was flat, except for the 3/16" plastic triangles on the floor to designate the loading. And the 1.5" tubes you might get shoved over while scoring a Tetra.
You can go less than 0.5" (I have seen many successful bots do this), but I would caution going much below that.
Unread 30-08-2012, 16:57
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I concur with IKE
FIRST has a tendency to put plywood and metal plates as field element bases under the carpet, and most of the time that results in about a 1/2" lip in the carpet. I've seen many robots over many years get hung up or spun around when they hit one at the wrong angle, or get pushed over it. Not worth risking when it's easily avoided.
Unread 30-08-2012, 17:05
AdamHeard's Avatar
Lead Mentor
It's worth pointing out that ground clearance between the wheels, and ground clearance in front of the frontmost wheel (ditto on the back) have different needs/affects.
Unread 30-08-2012, 18:40
Andrew Lawrence
Posts: n/a
Thanks everyone! I've redesigned my chassis so that there will be 7/8" ground clearance. Makes a lot more sense, and the redesign has allowed me to loose some weight. (I'll try and get a CAD up once the CAD team starts meeting)
Unread 30-08-2012, 22:35
FRC #1836 (MilkenKnights)
Another thing about the inconsistent turning axis is that it can be used to your advantage with the right drivers and driving practice. Watch the 2011 Einstein finals(both matches) and watch 254 very closely. You will see that they do this. One example of the right way to use the inconsistent turning axis is when they come from picking up a tube in the feeder station. They transverse the whole field backwards and then right before they get to the racks, they brake, shifting their turning axis and causing them to use the turning axis closer to the racks, allowing them to turn and immediately score instead of having to turn and then drive closer to the racks.
Unread 31-08-2012, 02:17
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
MIssin' the MItten
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Darn, i just got the math ready. But yeah, the low clearance wouldn't have been enough to go over the bump or even get on the bridge. (you could climb over a 2.13" barrier or drive onto a 3.6 degree incline)
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 31-08-2012, 04:09
AdamHeard's Avatar
Lead Mentor
Very interesting observation. I'm stoked to see what you guys come up with for 2013 btw.
