Go to Post The problem with anecdotal evidence is that you never seem to get the whole anecdote. - Lea DeFoote [more]
Unread 11-01-2003, 21:03
GMitchell GMitchell is offline
#0814 (MegaForce Squadron)
GMitchell is an unknown quantity at this point
Question More Pneumatics Limits
I'm being bothered by my team about the limits of the pneumatics system - does anybody happen to know how much pressure we can have at any given point in the system? Can we charge the 2" storage cylinders to something over 60? Do we have to do something to limit some given part of your system to 60 PSI? How confused am I getting this time?
- Griffin Mitchell
Mentor, Team 814
Gilmore Foundation and New Technology High School
Napa, California
"I think that what the woods lacks in internet connectivity it makes up for in dirt and bears." - Dante (Angst Technology - www.inktank.com)
Unread 11-01-2003, 21:19
Quentinfool's Avatar
Quentinfool Quentinfool is offline
#0217 (Thunderchickens)
Quentinfool is an unknown quantity at this point
last year the total pressure could not exceed 120 psi. i dont think that has changed but you'd have to check the rules.
Unread 11-01-2003, 21:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
You can have your tanks at 120 psi but the rest of the system can only run at 60 psi.
Unread 12-01-2003, 19:59
ah yes. that sounds familiar
"A strange game. The only winning move is not to play"-War games
Unread 12-01-2003, 20:20
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
and altho the rules dont state it.. the pressure gauge MUST be in the system... we left it out in 2001 because of weight concerns and FIRST made us put it on so that the inspector could check the pressure and it had to be left on.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 12-01-2003, 20:28
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
This is somewhat of a grey area that somebody should probably check with FIRST about. We also left out the gauge last year because of weight (129.7 lbs!), and, like you, the judges made us put it in to check the pressure. I've never understood why, since the Norgren relief valve won't go above 60psi, but that's another topic altogether... However, the judges allowed us to remove it immediately upon seeing that we were indeed set to 60psi. Oh well.
--Rob
Unread 12-01-2003, 20:32
The big guy
Yep thats what we told them too.. that the regulator wouldent do over 60.. he said it still needs to be there.. and then he made us keep it on...
luckly it wasent a problem
Justin Stiltner
KI4URQ
Unread 13-01-2003, 11:25
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Am i correct in assumeing that this years system can only get upto 115lbs of presure due to the fact the presure switch operates between 95 and 115 psi?
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 13-01-2003, 12:03
The rules state that you can store up to 120psi. The difference between 115 and 120 is so negligible that I wouldn't worry about it in the lease.
Unread 13-01-2003, 16:47
You don't have to use the switch if you don't want to. You can run the pump continuously and let the pressure relief valve do it's job.
Now granted, I'm not sure why the extra 5 psi is worth overworking your compressor, but it's a possibility
PNEUMATICS PLEASE HELP archiver 2000 1 23-06-2002 23:06
pneumatics archiver 2000 3 23-06-2002 22:58
pneumatics CD archiver 2000 2 23-06-2002 22:46
Filling the pneumatics tank archiver 2000 4 23-06-2002 22:43
pneumatics archiver 2000 1 23-06-2002 22:42
