Go to Post One thing that FIRST has given me ... Friends who care. - Arefin Bari [more]
Unread 30-08-2012, 18:34
Re: WCD vs Standard
Originally Posted by LedLover96 View Post
What does 25 do? why are they an exception?
6WD flat. I don't know how they do it, but they don't bounce when turning, even with high-traction wheels. I think it has something to do with how they groove their tread, but I'm not sure.
At least, they used to do that. I'm not sure if they still do or not.
Unread 30-08-2012, 22:18
FRC #1836 (MilkenKnights)
Re: WCD vs Standard
For weight it honestly depends: if you are running tube then WCD is a pretty good choice to save weight. If you are running sheet there is really no need to run a WCD. However wether you run sheet or tube you always should drop the center wheels and should direct drive the center wheel.
Unread 30-08-2012, 22:24
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Re: WCD vs Standard
And I am assuming that the standard KOP C-Channel will not work for a WCD, or, at least, that C-Channel is not a good choice? I have never heard of a C-Channel WCD.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 30-08-2012, 22:41
Re: WCD vs Standard
The KOP is not made for running a WCD. WCD is overall a better drivetrain, but for teams that don't have the capabilities to build a WCD the KOP is a find alternative. I believe they even make supershifter mounts for the KOP
Unread 30-08-2012, 22:45
UAH Class of 2019
Re: WCD vs Standard
Why can you not run a WCD on a KoP chassis?
Unread 30-08-2012, 22:59
Re: WCD vs Standard
The definition of WCD usually means that you are running a cantilevered, live axle, direct driven a dropped center drivetrain. While the KOP is drop center, it is not any of the other things. The C Channel of the KOP is definitely not strong enough to cantilever something off of it. because you are not cantilevering you might as well run a dead axle set up.
Unread 30-08-2012, 23:01
UAH Class of 2019
Re: WCD vs Standard
That makes sense, thanks.
Unread 30-08-2012, 23:53
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: WCD vs Standard
Technically you can make a WCD using the KOP but it isn't the most efficient way. The team who made it escapes me but I know there is a photo here on CD.
How they did it was they took the outer most rails in the standard KOP frame and moved them inward so they ran flush with the inside rails. This meant all they had to do was put their KOP bolts through the holes with chain and sprockets and they had a WCD. Cantilevered in all.
This method could make for a great fall project for any team that doesn't want to spend money yet still wants to work towards custom drivebases. Who knows, we might do it this fall just as a learning experience!
1058 PVC Pirates 2016 - xxxx
Unread 31-08-2012, 03:34
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: WCD vs Standard
Originally Posted by MattC9 View Post
Do you have solid proof that WCD are lighter than any other drive?
Matt,
I can't think of another drive that would be lighter than a WCD other than a super pocketed sheet drive. I'm curious to see the weight comparison and sheet drive.
But WCD is decently light due to the fact:
-No outer Railing
-Minimal amount of parts.
-Smaller parts: Wheels/Sprockets/Gearboxes etc....
We switched over to WCD in the fall of 2010. Never looked back (thanks 973!), its such a nice system that 254/968 has perfected over the years.
-RC
R.C.
MadTown Robotics Team 1323
Unread 31-08-2012, 09:13
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: WCD vs Standard
While not the traditional wcd, doing one with fixed wheels and belts would without a doubt result in the lightest drivesystem in FIRST.
That said there is really no right or wrong answer. Do what works best for you. If your main manufacturing resources are sheetmetal then WCD might not be the best choice. It is possible and we have actually run a sheet WCD before but it's not the best use of resources.
Mentor 2415
Unread 31-08-2012, 19:28
Kristian Calhoun's Avatar
Kristian Calhoun Kristian Calhoun is offline
Celebrating 21 years of 25
FRC #0025 (Raider Robotix)
Kristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond repute
Send a message via AIM to Kristian Calhoun
Re: WCD vs Standard
Jared from 341 made a really good post about our drive train about two years ago: http://www.chiefdelphi.com/forums/sh...5&postcount=31.
Raider Robotix: Home | Twitter | Facebook | Instagram
Brunswick Eruption: Home | Twitter | Facebook
Unread 02-09-2012, 11:14
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: WCD vs Standard
Originally Posted by SuperNerd256 View Post
No outer framing. Basically eliminates about 86" of outer railing (assuming a 37" long by 27" wide bot). Center wheel is direct drive, so less chain (6 chains per average 6WD, 4 for your average 6WD WCD).
Could you show the mathematics for that? West coast drives have to carry the same amount of force that a standard chassis chassis does. Keeping in mind that both have the same load requirements, I see no reason that one can't be engineered to the same weight as the other. West coast style introduces a rotational component that needs to be accounted for that astandard chassis does not require.
Nothing stops a team from direct driving on a standard chassis, and a standard chassis does not require bearing blocks.
Unread 01-10-2012, 22:34
UAH Class of 2019
Re: WCD vs Standard
Okay, new questions to ask.
In my WCD design I have designed the wheels to be far enough from the outside to allow for interchangeable wheel sizes of 4in, 6in, and 8in. Is this a good idea? I have read somewhere that you use 4in wheels to save weight, go faster, and keep your wheels as far to the outside as possible. Is this true? Should I design my WCD to use one type of wheel?
Also, can you weld the AM Flanged bearings to standard aluminum wall? (6061 I think).
Thanks!
Unread 01-10-2012, 22:41
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: WCD vs Standard
Generally speaking the bearings are pressed into the alum, or sometimes held in place with super glue if needed.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 01-10-2012, 22:50
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: WCD vs Standard
Thanks!
Smaller wheels will in fact make the robot go slower at the same gear ratio. Wheel size shouldn't be considered in terms of speed, as you should be adjusting your gear ratio to account for the wheel size. However the 4" wheels will save weight and widen your wheelbase, as opposed to 6" and 8" wheels.
Typically, teams press fit bearing, as opposed to welding them.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
