Go to Post Figuring out how to do something is half of the fun. - Mike [more]
Unread 04-09-2012, 09:20
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Colson center drop
OK all you Colson devotees, what would you recommend for the amount of center wheel drop using 4" Colson wheels in a standard 6 wheel long configuration?
Would that change for a short wheelbase?
Thanks
Unread 04-09-2012, 09:51
Chris is me's Avatar
AKA: Pinecone
Re: Colson center drop
We did 6 wheel short with six inch colsons, 1/8" drop. That combined with a precarious CG was too "tippy" for us, especially on the bridge, so we removed the center wheel and ran the whole season just fine. Basically, for a wide base you only need 4 wheels. You probably won't have a problem with "tippiness", but it's neat that you don't need to do anything special to make a wide base turn well with Colsons.
Unread 04-09-2012, 11:06
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
The 6WD (2011) and 8WD (2012) that 2168 ran with colsons both had the center wheels dropped .125". While I'm sure we could have gone a bit less on the drop, it was safe and we maintained "rock" even after the whole season on a single set.
Unread 04-09-2012, 18:40
trilogy2826's Avatar
trilogy2826 trilogy2826 is offline
Mentor - 2826
AKA: Jake Fischer
FRC #2826 (Wave Robotics)
trilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond repute
Small sidetrack first:
2826 has built 11 drivetrains in the four years we have been competing:
Competition:
2009: 3 wheel crab, Wide
2010: 4 wheel longitudinal beam suspension (2 traction in front, 2 omnis in back), Long
2011: Octocanum, Long
2012: 8 wheel, 2 center drop, 5" Colsons, Long
Offseason:
4 wheel independent Crab, 15" mecanum (yeah, 15"), 6" mecanum, 6WD drop center. 2WD with rear casters, Butterfly drive, plus some various prototypes that are more or less bits pieces.
Two things that really stand out from what we've learned:
1. Never use mecanums unless they are for whatever reason mandated by FIRST (sorry to all you mecanum lovers out there)
2. Colson's in a drop center drive make a fantastic drivetrain.
Back on topic...
This last year we switched to Colson 5" for IRI from a custom wheel that we designed. The drive was an 8WD with the two middle axles on the same plane dropped 0.125 wrt the outboard axles. The wheelbase between all axles was an equal 9.25 in. We found that when we moved to the Colsons, there was an excessive scrub when turning resulting (what we believe) from 3 wheels on one side touching momentarily. This caused, to some degree, the same effect that a long 4WD with tractions is known for (hopping, excessive battery drain). We cheated and shaved down the diameter of Colson's on the outer axles to increase our "drop". We ended up with 5/16" vertical difference between the outer and inner axles, even though they were only 9.25 inches from each other.
Needless to say, this bothered the heck out of me, so we dug into it over the last month. I know we haven't yet discovered all the root causes, but these have led us to rethink a few things.
First off, my definition of how to measure "drop": Draw a ground reference line. Draw a line parallel to this ground line between the center of both outboard wheels. The center of the inboard wheel(s) is below this line by your drop distance. This might seem obvious, but I want to make sure I am stating everything following from a baseline.
Root causes of the design failure:
1. Lack of understanding of the geometry: We simply went with an 1/8" drop because our CD research pointed to that being an optimal place to start. In a 6WD, 1/8" makes sense. If you take a symmetrical 6WD with the center dropped 1/8" and you rock the chassis so that the "rear" and middle axle wheels are resting on the ground, the lifted wheel is raised from the ground 1/4"
In the 8WD with the outboard wheels raised 1/8, you first need to decompose this into a mini 6WD. This is easiest to imagine by simply deleting one of the outboard axles
In this case, the effective raise of the outboard axle is only 1/8". This lower clearance, combined with the following, caused our issues
2. Carpet to Colson compliance: On a consistently hard surface like linoleum or concrete, this small clearance works perfectly well, with no hopping. Though FRC carpet is pretty compact, it can flex and compress a significant amount under stress. This added to a full robot weight on top of one wheel (the dropped wheel in this case, on one side of the bot), will allow your raised, non-compressed wheels to touch the ground simultaneously.
3. Dynamic turning compliance of colsons: Didn't know what else to call this. Based on high speed video, we determined that while turning, the Colsons tended to compress even further past their static state mentioned above. We attribute this to two possibilities: increased force on the wheel based on simple dynamics and the thought that the urethane "twists" causing the material to locally compress. While we were not able to definitively measure this effect, based on video while on concrete, we believe this can account for at least an additional 1/32" of compression.
Solution:
We are going toward specifying relative angles dependent on wheelbases instead of just drop. This is also based on just looking at a simpler 3 wheel per side model, no matter the amount of wheels. I plan on putting out a whitepaper soon on this topic, so please shoot holes in my process now.
Last edited by trilogy2826 : 04-09-2012 at 18:42. Reason: Tried to draw ASCII pics of my theory, but didn't pan out quite right
Unread 04-09-2012, 19:12
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Competition:
Another sidetrack, but I just want to point out that 2826's most simple drive train coincides with their most successful season. Coincidence? I think not.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 04-09-2012, 19:46
AKA: Pinecone
Jake,
One other thing I'd look into with regards to turning scrub problems would be how rigid your frame is diagonally (cross-corner). A less rigid frame is more likely to flex just a little bit and result in the outer wheels touching the ground when they shouldn't, leading to the problem you described. From what I've seen of your frame this year, it really shouldn't be an issue, but I've seen it happen to a few teams. I think this is part of why the Kitbot has a larger drop than average - the frame is less rigid than a more solid welded frame.
You may be able to avoid the dynamic turning compliance problem with wider Colsons. I noticed at IRI that your drive base was running very thin (7/8") Colsons - experimenting with 1.5 inch wide Colsons, while it will add some weight, could help a bit too. Since the weight of the robot is distributed across more tread, there should be less localized pressure on the tread and thus you might get a bit more freedom turning. I know this sounds counterintuitive, but we've had great results with the wider Colsons and I thought I'd just throw in another data point to test.
Unread 05-09-2012, 11:52
Brandon Holley's Avatar
Our 2011 DT was a 6WD, drop cetner w/ 4" X 1.5" Colsons. We dropped the center wheel 3/32". This worked well, but was a little on the too grippy side for us, so we went to 1/8" on our 8WD this past season.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 05-09-2012, 13:23
Have you guys modified the tread pattern at all when using Colsons or flattened down the wheel? (Not sure if they all come with a tapered tread). If so, did you see any benefit in performance/turning?
Unread 05-09-2012, 13:48
We did cut treads into our Colsons this year and saw improvement, mainly in traction. We were measuring somewhere in the ~12% range for the pattern we used.
Flattening the wheels on a belt sander also appears to be something we'll explore as we move forward. We flattened a few of our wheels this past year. We'd like to try flattening them and then cutting the tread pattern into them and seeing what kind of performance we get.
Even with all these tweaks, we still felt even regular old off-the-shelf Colsons are more than acceptable.
-Brando
