Go to Post And, learn to collaborate, 'cause it works. - DonRotolo [more]
Unread 11-01-2003, 17:14
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Originally posted by Billyp04
on my operator inter face the PMW2 led is lightup. also the right side of the robot does not move but when i swich the two servo connectors arount thr right side of the robot moves but the left side does not. i am using the 2003 first default program both programs r in the robot the user works eveything else runs.can any one help me with this program?
PLEASE speak english. "r" is not a word, nor is "i" unless it is capitalized. Same with "thr", "arount". Beginnings of sentences are capitalized, and periods are required between them. Commas are good, too. If you look through all the other posts/threads on this board, you will find very few that aren't writen in fairly good english. Please follow their example.
I see no reason to waste my time trying to understand what you are saying; answering a question, on the other hand, is not a waste of my time and I am happy to do.
Unread 11-01-2003, 17:22
GMitchell GMitchell is offline
#0814 (MegaForce Squadron)
GMitchell is an unknown quantity at this point
Question Well, let's see if I can confuse myself...
I was going to offer a possible solution, but after typing a few screens worth of text, I realized that I was just ranting and didn't know enough about the problem.
Are the motors that are having problems controlled by relays (in which case I may know the solution) or by PWMs (in which case I don't)? Are you controlling things with the joystick... (err... axis' axes? axi? How do you pluralize axis anyway?) Anyway, are you controlling (or trying to control) the robot by moving the joystick or using the buttons? What is hooked up to where? How did you re-download the 2.5 code to the RC with a 2.0 editor?
- Griffin Mitchell
Mentor, Team 814
Gilmore Foundation and New Technology High School
Napa, California
"I think that what the woods lacks in internet connectivity it makes up for in dirt and bears." - Dante (Angst Technology - www.inktank.com)
Unread 13-01-2003, 09:46
Billyp04 Billyp04 is offline
#0905 (platt tech panthers)
Billyp04 is an unknown quantity at this point
helllllp me please
Unread 13-01-2003, 10:41
With what?
If you look through this thread, you'll notice two types of responses: some that offer suggestions, and others that don't understand what you are asking. Have you tried all the suggestions rwaliany made?
In either case, you're going to have to explain your problem (preferably in English) in a way that we can understand. As of right now, I only know that it's not working and something about PWM2 being broken.
Unread 13-01-2003, 11:36
Geoff_494 Geoff_494 is offline
#0494 (Martians)
Geoff_494 is an unknown quantity at this point
Send a message via AIM to Geoff_494
As has been stated, it's not entirely clear what the problem is, but assuming you are using two joystick tank drive, are the joysticks plugged into port 1 and port 3? I believe those are the ports used in the default code for the left and right drive variables.
Unread 13-01-2003, 13:39
Christine_364 Christine_364 is offline
#0364 (Team Fusion)
Christine_364 has a spectacular aura aboutChristine_364 has a spectacular aura aboutChristine_364 has a spectacular aura about
I cannot really tell what the problem may be without more specifics.... but you need to check and make sure that your joysticks are o.k...... you can try this by swapping them around to see if the problem follows one or the other. You also need to make sure that your joysticks/speed controllers are 'calibrated'.... sometimes you need to adjust the wheel on the base of the joystick until the LED on the speed controller is steady on. It will turn green or red whenever you are trying to control the motor in a positive or negative position. Check the breakers and fuses to make sure that nothing is burned out or tripped. You can also try to swap speed controllers, if that is what you are using.... and make sure that you have the right PWM channel going to the right controller.... it is easy to think you are on channel "x" and you're actually on channel "y"....
If you go through each of these possibilities and it still doesn't work, e-mail me directly: christine.q.powell@nasa.gov
Good luck!
Christine
Unread 13-01-2003, 14:39
Ryan Meador Ryan Meador is offline
Team Role: Electrical
Ryan Meador will become famous soon enough
I am no doubt horribly confused, just as is everyone else, but I have a different take on things. It seems to me that you're trying to use one joystick drive but have the two joystick program in the RC. I don't know what that would have to do with the PWM LEDs, but it would explain why only half the robot works.
-Ryan
"You're not a real programmer until you end all your sentences with semicolons;"
Unread 13-01-2003, 15:40
your not smart tell me something i don't know
Unread 13-01-2003, 16:14
Electrical Engineer
Rookie Year: 1995
Billy,
What these responders are trying to say is that we do not fully understand your problem. You say your PWM2 is broke but do not say what code you are running or what diagnostics you have attempted.
My team, Bobcat Robotics are in South Windsor CT and I have been doing this for 9 years now. Perhaps you could have Mr. Jones or one of your other adult advisors give me a call if they would like to try and solve your problem.
My number at work is 860-727-2478. I'll be at work between 7 AM and 4 PM tomorrow and we'll see if we can help you out.
Mike Betts
As easy as 355/113...
Unread 13-01-2003, 23:27
The problem might be that you are not connecting the left wheel's motor into the proper pwm output: I had that problem with the EduBot, too. Check the manual to make sure that your outputs do what you want done.
Unread 14-01-2003, 07:55
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Man, that was harsh. On the sense of that statement, at least he can explain his question thoroughly.
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 14-01-2003, 15:48
rwaliany's Avatar
rwaliany rwaliany is offline
R
None #0691 (HartBurn)
rwaliany will become famous soon enough
This is a useless post. The questions are unclear (in what I would not even call english). The person who is asking the questions, Billy, is mimicking the people who are trying to help.
"Billyp04 your not smart tell me something i don't know"
If that was the problem didn't I tell you that (along with a way to fix it) in my first reply to your question.
This seems pointless messaging you about how to fix it.
http://www.innovationfirst.com/FIRSTRobotics/
They have some pretty good documentation, try it. I'm not going to waste anymore time reading non-sense.
R
2-week FIRST summer program @ WPI ColleenShaver General Forum 20 31-05-2009 03:02
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
default program nick_champ_2 Programming 2 06-02-2003 13:11
Ahh! Program trick confusing! archiver 2001 9 24-06-2002 02:26
robot control emulator for default or other program CharlieWilken Programming 26 24-02-2002 02:36
