Go to Post Everyone needs to please stop now before Karthik starts singing. - dlavery [more]
Unread 26-07-2012, 22:39
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Bevel Gear Machining.
In the car world, the big advantage of spiral bevel gears are their much quieter operation and their somewhat longer life. The disadvantage is their higher production cost.
In your circumstance, I think ease of manufacturing would trump all that.
It is possible to make a flat straight-tooth bevel gear, but strength, durability and efficiency suffer. Really, the big gear is flat, and the pinion looks like a spur gear but with tapering teeth - the tooth profile is not constant, but gets thinner towards the far end. Generally the pinion is not very wide, maybe 1/2" - 3/4" for the kind of sizes I think you're working with.
Maybe try it with some machining wax, machining foam, or maybe soft brass?
Unread 05-09-2012, 21:38
Orangedesign Orangedesign is offline
AKA: Mingyi Chen
FRC #4159 (Cardinalbotics)
Team Role: CAD
Orangedesign is an unknown quantity at this point
Hi FRC teams! As a team with little experience, we are trying to move away from imprecise tools. What would be a good and cheap 3/4 axis mill (~$2000)? Are used ones ok? Are complex parts manufacturable with better manual tools (ie manual lathe/mill)?
Many Thanks
Unread 06-09-2012, 15:21
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
There are good inexpensive mills that can do the job just fine for most of the work an FRC robot needs.
We have access to a HAAS four axis once in a blue moon, but most milling last year was done using a Grizzly 1007 manual mill with an autofeed table. It goes for ~$1700. Harbor Freight has a slightly lower model as well (different paint and without autofeed) for $1100 (#33686).
Grizzly has some inexpensive endmills (~$90 for a set in R8 collet size). Spend the money on a precision machining vise. Grizzly sells some as well.
I would budget about $2500-3000 minimum for a good size setup considering the clamps, collets, endmills, cutters.
You can also retrofit one of the Harbor Freight mini mills (#44991) with a X2 CNC kit for <$2000. They sell the mini-mill for $600 and they may accept the 20% off coupons that are always floating around.
I'm sure there are plenty of other options out there as well.
I would post links, but I think that sends my posts to pergatory for now while I get my post count up.
Unread 06-09-2012, 15:26
DonRotolo's Avatar
Back to humble
FRC #0832
Used tools are OK, and can often get you much more machine for your money.
Search ChiefDelphi for many, many mill recommendations. I remember Dave Lavery offering a particularly good choice.
Far more important than the quality of the machine is the quality of the operator. An excellent operator can turn out world-class items from a poor machine, and a poor operator* can fail to turn out usable items from the finest machine on the planet.
Many schools / teams decide that CNC is the way to go, as a way of compensating for their inability to actually operate a milling machine. They let the computer make the decisions, and the result is just fine. I am of the opinion that having one or two kids on the team become excellent operators is a far better method.
So, find a local machinist or three, and see if you can get them to teach someone - ideally a Sophomore (who will be with the team a while) how to use a manual mill. And/or maybe introduce you to someone in the used machinery business who can find a nice machine with tooling (which costs as much as the machine!) that's within your budget.
My 2 cents.
*=almost any high school student who hasn't been taught.
Unread 06-09-2012, 15:51
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Get someone who knows what to look for and find a used Bridgeport Series I/clone (Webb, Acer, Sharp, Lagun, Wells Index, many others) that's in good condition.
You can likely find an older one for about $2000-2500. This is something that's worth waiting and saving more if it means jumping from a Chinese benchtop mill to a US/Taiwanese/Spanish (Lagun) made knee mill. There's no comparison.
I would probably start with a lathe first if you have no machine tools.
2001-2004: Team 100
2006-Present: Team 254
Unread 06-09-2012, 16:12
AdamHeard's Avatar
Lead Mentor
Better than any specific advice we can give you regarding machines is you that you need to find someone local (like a machine shop) who is willing to help you out.
Maybe they won't give money, or make parts; but they can still be incredibly valuable providing advice, old tooling sometimes, advice/training, etc...
Many of our shop sponsors never even run parts for us, but are invaluable for advice and fixes.
That being said, old machines of a nice brand in fair condition will be your best value in the machine market. You need someone experienced to help make that call though.
Unread 06-09-2012, 21:34
FRC #1836 (MilkenKnights)
I was going to ask our machine shop also, but I wanted the point of view from experienced FRC teams: if we want to get a lathe in the same price range ($2000 - $2500) what kind of lathe should we get. We will probably get the space for a full size lathe, but I would also love recommendations for table top ones in case we don't get the space.
Unread 07-09-2012, 00:48
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
For years now, I've been recommending the Harbor Freight 44859 "8x12" lathe as a good benchtop model for those on a budget. I've had mine since 2006 and I have it on top of one of their 13-drawer tool chests which are also fantastic. The lathe actually measures 8x14 in size (according to how lathes are properly measured) and weighs a good 200 lbs or slightly more. I'd stay away from the 7x series import lathes. They're just too small. The 44859 has been a good unit with great precision and really no problems to note. It's a durable belt drive, with steel gears for the lead screw. It lacks a quick change gearbox, but how often are we doing thread cutting anyhow. If had it sitting right next to our refurbished 1961 Logan 11x24 which has been retrofitted with a VFD and QCTP, I'd probably most often still elect to use the Harbor Freight lathe just because it's a newer tighter machine that holds good tolerance and isn't worn out like our old Logan is. The HF lathe costs a lot more now than it did in 2006, but, everything does, and you can still try to get it with a 20% off coupon (one of my reasons for purchasing when I did). There may be a few things you'll need to do that exceed the size, rigidity, horsepower, etc of this lathe, but it can do quite a lot, even being on the smaller side. As a matter of note, the LatheMaster 8x14 is essentially the same machine with different paint.
Unread 07-09-2012, 01:02
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Even better:
http://littlemachineshop.com/product...ly_special.php
One of our mentor has it, and I gotten to run a few parts on it it; pretty solid little machine. And as with any machine good sharp tooling makes a world of difference.
If you can house one, any Bridgeport or clone is infinitely better then any Chinese import desktop milling machine. If you don't have room for one, have a look at the RF45 Mill or similar and if even that is out of your budget LMS' http://littlemachineshop.com/3960 is a decent option.
And as the said above, having a guy that really knows how to run a machine is usually more important then what kind of machines to get.
This is interesting... seeing that CNC is a LOT more expensive and personally I find manual milling for basic parts compared to CNC usually as simple and sometimes faster. Though our new off season bot is almost 100% CNCed... heh.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 07-09-2012, 09:54
Originally Posted by Mk.32 View Post
While this is a decent machine, I'm going to have to disagree with you here. Aside from this 7x12 having digital readouts and variable speed, the "8x12" (8x14 actually) is much more of a lathe than any 7x12 ever will be. It's physically about twice the overall size and weight, and can take a lot heavier cuts.
Unread 08-09-2012, 01:28
Mk.32's Avatar
AKA: Mark
OH... my mistake I didn't realized that the HF was a 8x12... heh
But yeah the HF is definitely a better deal
