Go to Post Not only does Dave like to post hints about the the new game...but now he's starting to post hints about the activities of the Mars rover. Does it ever stop?! - Alexa Stott [more]
  #31   Spotlight this post!
Unread 08-09-2012, 14:50
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
Re: FRC Blogged - KOP Evolution
Originally Posted by jason701802 View Post
That's assuming the kitbot is value-less, which it certainly is not.
It's interesting that the kitbot kit is $400 (of course that may change for the new kit), so a team could take the voucher, buy the kitbot kit, and still have another $50 to spend however they wish. Unless I'm missing something, it's essentially the same as not taking the voucher, and then getting $50 in AndyMark credit for free.
Wrong. The 2013 kitbot will have mini-toughboxes, not CIMple-boxes, which is another ~35$, and contains 4 CIMs (well, it did in 2012), not 2, which is another ~50$, so doing that you would actually lose money.
edit: Chris is me got ahead of me...
  #32   Spotlight this post!
Unread 08-09-2012, 15:11
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Originally Posted by Chris is me View Post
A few things to note:
1. The above kit uses the old FIRST wheels.
2. The above kit uses roller chain for four of the wheels and nothing for the front 2, instead of a six belt solution.
3. Only comes with 2 CIMs (I'm not sure if the new kitbot comes with 4 though)
4. You have to wait to get that kitbot a few days rather than getting it on Kickoff Day.
1 & 2) Yes, but it's not unreasonable that they would release this years kit at a similar price point.
3) The KoP has never come with 4 CIMs, why would they start now? (This is also dependent upon whether the CIMs are considered part of the "2013 AndyMark Kit of Parts Drive Base". I wouldn't consider them as such, but I'm not FIRST)
4) That's might not be a bad trade off for $50.
I did miss the part about the ToughBox Minis
Also, see my edit to my post above
Jason
  #33   Spotlight this post!
Unread 08-09-2012, 15:21
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
The 2012 only had 2 CIM motors.
  #34   Spotlight this post!
Unread 08-09-2012, 15:42
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
I really hope that they release the new kitbot specs prior to 10/18. They say that it will be belt drive, but gates doesn't make a 6-bolt pattern sprocket that would fit onto a wheel so the only option would be for gates to make a custom sprocket just for the kit (unlikely) or for the kitbot to switch to a live axle system (also unlikely). Either way it will be a massive step up from the current kitbot.
The whole point of the kitbot is that it's easy to make, reliable, strong and simple. I wouldn't expect First to release a kitbot that isn't those things, and if they can pull that off with a belt drive then that'll be a drive train better than most teams can custom make.
  #35   Spotlight this post!
Unread 08-09-2012, 15:43
scottandme's Avatar
scottandme scottandme is offline
AKA: Scott Meredith
FRC #5895 (Peddie School Robotics)
scottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond repute
I'm interested to see the layout of the kitbot chassis using gates belt. The stated numbers (10.7:1 reduction and ~10fps with 6" wheels) suggest that there will be no further reduction via belt, so I wouldn't count on multiple pulley sizes.
  #36   Spotlight this post!
Unread 08-09-2012, 16:05
IndySam's Avatar
I could easily see a extrusion made with the six hole pattern required for the standard wheel hub made for the kit. 1000 kits, 6000 sprockets plus spares for purchase. Add on a two or three year commitment it could be done very economically.
  #37   Spotlight this post!
Unread 08-09-2012, 16:07
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
True,
Although if FIRST is working with AM, AM/Andy could make an extrusion (with the 6 bolt pattern) for the pulley and then send it out for machining (most likely a boring operation and parting).
-RC
R.C.
MadTown Robotics Team 1323
  #38   Spotlight this post!
Unread 08-09-2012, 16:33
Originally Posted by R.C. View Post
True,
-RC
I was thinking the same thing, if they were to use a custom extrusion I would hope they include a 1.125 bore hole in the pulley extrusion. That would keep the sprocket concentric with the wheel and if the hole was extruded instead of bored they could save a lot of material and end up with a very light well priced product.
However I'm sure First/Gates/Am want make the kitbot as simple as possible and would want to use existing off the self components, but that might not be possible or plausible.
The other thing that this kit might bring us is new belt drive products from andymark, as belt seems to be the direction FRC is going in.
Edit: You and Indysam think alike
  #39   Spotlight this post!
Unread 08-09-2012, 17:41
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
I would be 100% excited if AM/ gates released a belt line for FRC, and if the belts were a little thinner I would greatly appericeate it.
  #40   Spotlight this post!
Unread 08-09-2012, 18:29
AdamHeard's Avatar
Lead Mentor
Originally Posted by David Doerr View Post
I'm leading a rookie team in 2013 and we've been active for the past month or two trying to prepare for the season. I submitted a reply to the FRC blog and I did my best to be diplomatic. I'm going to be more candid here.
I think it stinks that rookies don't have the same opportunity for a voucher that veteran teams do.
I run a good team and know a great deal about drivetrains. 973's drivetrains are top tier.
If I walked today and started a rookie team, even with experienced students/mentors and a stocked shop, I would run the KOP drive as a rookie.
I think preventing rookies from accidentally making the wrong choice is a great decision.
  #41   Spotlight this post!
Unread 08-09-2012, 18:40
Best Available Data
FRC #1778 (Chill Out!)
I think there is a very significant portion of veteran teams that would benefit more from using the KOP chassis than giving them a $450 voucher. How come it isn't in our best interest to prevent them from making the wrong choice?
In 2011 half of FRC couldn't put up more than one tube in a match or launch a minibot, and there weren't that many rookies.
  #42   Spotlight this post!
Unread 08-09-2012, 19:10
David Doerr's Avatar
David Doerr David Doerr is offline
FRC #4478 (Materia Oscura)
David Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud of
I'm certain you do know a lot more than I about drivetrains, and I likely would agree with you after I see the game that the KOP drive would be used for, but...
...suppose you had already raised and spent money on a C-base chassis, two toughboxes, CIMs, along with other components so that your team had something to work with during the pre-season time period. It's tough for a rookie team to get those $$ together. Wouldn't you want to be able to use a voucher for parts other than those you had already purchased - the same as other teams are able to do - rather than receiving near duplicates in the KOP?
  #43   Spotlight this post!
Unread 08-09-2012, 19:14
AdamHeard's Avatar
Lead Mentor
Sounds like a practice bot to me!
  #44   Spotlight this post!
Unread 08-09-2012, 19:21
Not all rookie teams are even in a position to fundraise enough to buy a Kitbot at this stage of the game. In fact, I would say that you're in the 1% or so that are. If I was a rookie, and saw that I could get a frame or $450, what would I go for? Probably the $450--not realizing how hard it is to build a custom drivetrain.
What FIRST is doing is, they are forcing the rookies to take a drivetrain and work with it during the season.
Maybe some of the rookies are doing that in the offseason. Well, I don't suppose that those rookies can repurpose some of that material into, oh, I don't know, superstructure? How about spare parts?
You're not wasting money. You're building inventory. And if your programmers don't have a testbed working by the time the real robot is handed over to them 2 days before bag, that's their problem. Practice robot, anybody?
  #45   Spotlight this post!
Unread 08-09-2012, 23:12
GaryVoshol's Avatar
Cogito ergo arbitro
...suppose you had already raised and spent money on a C-base chassis, two toughboxes, CIMs, along with other components ...
And just let them sit on the shelf until kickoff, because you can't fabricate anything you'll use in competition except during the 6 weeks, right?
(since 2004)
