Re: Andy Mark Supershifter with Pneumatic shifters
Yes you could get them at the hardware store, but probably not mil. spec. grade which would be significantly stronger than the commodity grade you will find at the store. It would be worth ordering several from McMasterCarr you would have them in 2-3 days. I believe AM used an extra-strength grade when they were using them.
Yes a standard fractional drill will work, the pin is slightly oversize and made to flex smaller when driven into a nominal size hole. I would think there is very little experience out there with solenoids on AM shifters since this was the first year solenod actuators were allowed. It would take a substantial solenoid to approach the force of a 1/2" air cylinder, and the size/power that is allowed is limited. To get push and pull motion you would need a push-pull solenod, or two solenods, or would have to combine it with a spring return which would increase the size needed. One would have to look at what power is allowed and see how the pull force could compare to air. You would probably need a contiuous duty type for long periods of being energized, which means less pull force for a given size. Getting to a force comparable to air would likely get pretty heavy. |
Well for a 20PSI 1/2 inch cylinder you would get about 4.5 lbs. Here's a random solenoid close to spec that is about 2.2 lb push, 6.6 lb pull. Could probably alter the spring to even out the force?
Thank you jspatz1 I'm gonna try this out by getting my own super shifter and try this set up out, and teach the team how to do it, I just hope I do it right
What is this solenoid shifter? And what advantages does this setup have, I saw the link. How does it work? |
With a pneumatic system you would need the storage tank, gauges, valves, regulators etc. |
What diameter pin should I use after I had drilled it out?
Hmmmm....I think the solenoid shifter is my next project, thank you for the input and advice What teams had used this solenoid set up? |
As I mentioned this is the first year solenoid actuators have even been permitted on a FRC robot, so there is no history of them being used for shifting that I know of. If someone successfully did this in 2012 I would be curious to hear about it. |
#7
Yes i agree with jspatz1 about this conversaion, but im also wondering about this solenoid shifter, if anyone has use this setup,please feel free to add to this conversation, i see the pros and cons about using pneumatic shifters......what are the pros and cons using solenoid shifters
#9
pros: less weight(no compressor and tanks)
cons: slower |
#10
Our own shifters we had, we've always run at 20 PSI for the solenoid valves sake. I was under the assumption that it took less force than the 12 lbs to shift but I could be wrong about this as I have no experience with the super shifters. Last edited by kevin.li.rit : 09-09-2012 at 21:57. Reason: Grammar |
#11
Another setup that I've heard of is using a window motor coupled to both transmissions with a spring setup to engage the gear if it is not lined up during the initial gear change request. I do not know what team had this setup, but it is definitely worth researching some more as it could offset the weight of a pneumatics system, even those with pvc air reservoirs. Last edited by protoserge : 09-09-2012 at 22:08. |
#12
That's a clue that I should go to bed.
![]() Fixed for posterity, thanks. Last edited by protoserge : 09-09-2012 at 22:04. |
#14
