Go to Post Keep your chin up, your safety glasses on, and don't let the magic smoke out of the electrical components and you'll do just fine :) - rsegrest [more]
Unread 08-09-2012, 22:34
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Question [FTC]: Ring It Up - peg heights/width
Did I miss it in the manual, or did they never mention how tall each row of scoring pegs are, and how far apart they are? They also didn't mention the height of the corner goal or ring dispensers..
If we're supposed to figure it out by building them and measuring, I guess we'll know in a week or two.
Anyone figure it out already?
FRC 2656 | FTC 5526 | VEX 9656
Unread 09-09-2012, 10:44
Paxorf Paxorf is offline
FTC #4299 (The Battery Powered Picklejar Heads)
Paxorf is an unknown quantity at this point
Re: [FTC]: Ring It Up - peg heights/width
I was at the kickoff and they measured the middle peg height: 36". I believe the others are each 12" off the middle one (in the Field Build Guide the PVC between pegs is 12" long). So the high one would be 48", and the low one would be 24".
Here's the Build Guide: http://www.usfirst.org/sites/default...e_09082012.pdf
Unread 09-09-2012, 12:20
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
I believe you can calculate it by looking here
I'll calculate it myself but it will be a little while before I finish... Plus someone should check my work!
Length = to around 40"
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 09-09-2012, 12:35
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Thanks Evan. I did try to calc it last night, but I was kinda burned out from the Kickoff event and brainstorming. And I suck at math. And, while they did show some PVC lengths, they didn't show the sizes of the connecting joints, which could be 1" - 3" on their own.
Mind bending...
Unread 09-09-2012, 16:16
At the kickoff yesterday I believe they said the middle peg was 36" tall. The PVC in between each level is 12", so the high one would be about 48" and the low one would be about 24". So pretty high, actually (unless I'm wrong).
Unread 09-09-2012, 20:09
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
They still havent released the field drawing that they had the last few years. I did yesterday though measure up to the top peg at the bend, and it was at 46.5 inches, which is a little werid when you take into affect the measurements on the field guide they do have out.
I cant find the height of the ring dispencers either, and when I caculate them out, they seem too high compared to what I saw yesertday at our kickoff.
Unread 10-09-2012, 13:07
I got a hold of FIRST on the FTC facebook page, and they just updated the Field Set-Up Guide with the heights. The dispensers, Corner Goal, and low Rack peg is at 18", middle peg is at 31" and 44" for the top peg.
Unread 10-09-2012, 15:10
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
VERY NICE MattRain! Thank you so much. Smooth move using Facebook. Wish I thought of that!
So the lower posts are all the same height as max-robot height. Interesting. And the other two are plus 13". Even more interesting!
