Re: Andy Mark Supershifter with Pneumatic shifters
With a pneumatic system you would need the storage tank, gauges, valves, regulators etc. |
What diameter pin should I use after I had drilled it out?
Hmmmm....I think the solenoid shifter is my next project, thank you for the input and advice What teams had used this solenoid set up? |
As I mentioned this is the first year solenoid actuators have even been permitted on a FRC robot, so there is no history of them being used for shifting that I know of. If someone successfully did this in 2012 I would be curious to hear about it. |
Yes i agree with jspatz1 about this conversaion, but im also wondering about this solenoid shifter, if anyone has use this setup,please feel free to add to this conversation, i see the pros and cons about using pneumatic shifters......what are the pros and cons using solenoid shifters
pros: less weight(no compressor and tanks)
cons: slower |
#7
Our own shifters we had, we've always run at 20 PSI for the solenoid valves sake. I was under the assumption that it took less force than the 12 lbs to shift but I could be wrong about this as I have no experience with the super shifters. Last edited by kevin.li.rit : 09-09-2012 at 21:57. Reason: Grammar |
#8
Another setup that I've heard of is using a window motor coupled to both transmissions with a spring setup to engage the gear if it is not lined up during the initial gear change request. I do not know what team had this setup, but it is definitely worth researching some more as it could offset the weight of a pneumatics system, even those with pvc air reservoirs. Last edited by protoserge : 09-09-2012 at 22:08. |
#9
That's a clue that I should go to bed.
![]() Fixed for posterity, thanks. Last edited by protoserge : 09-09-2012 at 22:04. |
#11
