Go to Post Different approaches to the same problem. Isn't it better to focus on understanding both than to be dogmatic about it? - Greg McKaskle [more]
Unread 09-09-2012, 01:49
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
Re: pic: First attempt at Sheet Metal Chasis
Originally Posted by Feroz1325 View Post
Looks good for a first time, however as others have mentioned you need space for a transmission in there, in our sheetmetal chassis we made mounting holes for the gearbox between the center wheel and the end and powered it via 35 roller chain.
Also be sure to leave sufficient ground clearance, many flat field frc games...aren't (bumps around towers in 2011, etc).
What thickness, material and bend radius are you using?
1/8 inch almuminum with a 2mm bend radius
