Go to Post Yellow bananas are the new red herrings. - artdutra04 [more]
Unread 08-09-2012, 17:23
Camren's Avatar
Camren Camren is offline
FRC #3081 (RoBoEaGleS)
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
[FTC]:Finding weighted rings vs regular rings
Okay so brainstorming a bit with some friends about this years FTC game Ring It Up! We came up with 2 easy ways of measuring the different rings and seeing that it is probably the most difficult aspect of this years teleop period I thought I would share and hear what everyone else has to say.
Option 1: Using a current sensor; If a motor needs to work harder to pick up a ring that must mean its heavier so if you measure the amperage the motor is drawing and having that read into a light that turns on or off depending on if the sensor trips.
Option 2: Use a weaker actuator on an arm that cant pick up a weighted. This is a solution for both motors and pneumatic's.
Yes I am biased towards opinion one that is why there is more text. I am anxious to here your ideas?
Unread 08-09-2012, 17:57
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: [FTC]:Finding weighted rings vs regular rings
Create a switch that will not trigger when something weighing less than 1 ounce... Then testing every ring, it would be most efficient to find a way to pick up the ring and then have your pick-up mechanism with a sensor on it. Basically eliminating the need to set the ring somewhere else on your robot.
This is my first season as a coach for FTC, I'm excited to see the competition! I'm also excited to make an awesome robot!
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 08-09-2012, 19:11
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Welcome To FTC!
However I would make it work for anything above 2 oz I know they light rings are .88 oz but to account for tolerance I'd say 2oz is safe.
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 08-09-2012, 19:18
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Lightbulb Re: [FTC]:Finding weighted rings vs regular rings
Some type of spring loaded trap door that rings slide/roll past and heavier rings drop through...
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 09-09-2012, 13:36
bvillahermosa's Avatar
bvillahermosa bvillahermosa is offline
AKA: Brian
FRC #2557 (SOTABots)
bvillahermosa is an unknown quantity at this point
the lighter rings are hollow so you could use a light on whatever you use to pick up the rings on the heavy rings the light couldnt get through but the light would get through on the lighter rings
Unread 09-09-2012, 13:44
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Rings are sold out on andymark... Assuming some FTC teams have already purchased them can someone post a picture when they receive them?
Unread 10-09-2012, 21:43
Tommy F.'s Avatar
Tommy F. Tommy F. is offline
Yeah! Collages!
AKA: 7h0m45
FRC #1985 (Robohawks)
Tommy F. is just really niceTommy F. is just really niceTommy F. is just really niceTommy F. is just really nice
I just found this today while looking at sensors for FTC.
http://www.hitechnic.com/cgi-bin/com...on&key=NFS1074
From what I see, it's like an analog touch sensor, and it won't be available until October, but you could use it to differentiate the weight of the rings.
FTC 289, 290 & 291 :: FRC 1985
2013 St. Louis Regional Semi-Finalist (with 3411 and 4330), Industrial Design Award
2013 Queen City Regional Winner (with 379 and 447)
Unread 10-09-2012, 22:17
Camren's Avatar
Great find I hope that manufacture a lot of those because I see them getting snatched up fast.
Unread 13-09-2012, 02:10
dtengineering's Avatar
AKA: Jason Brett
I don't suppose they are the same rings that VEX used a couple years ago? That would be just too convenient...
Jason
Unread 13-09-2012, 08:36
AKA: Andrew Remmers
Jason
Smaller, and Branded with FIRST logos. They also feel less cheap than the vex rings, probably due to their increased wall thickness.
As for sensing the wieght I have an idea for my design that would make it work. Since my robot (should) be able to pick up from both sides I would need two force sensors to figure out what the wieght one from each side. My claw would also need to pivot a smidge so that it could rest on the sensor given the orientation at any time. However instead of an automatic function I think a function for sensing should be on demand so that you can measure the wieght of said tube while the robot is -mostly- still so it gets an accurate measure without combining forces from moving around and getting ready to score. If the tube was weighted then an LED would light up somewhere on the robot to indicate that its a wieghted tube. From there you simply drive to the corner and score it.
Those are my ideas how to go about finding wieghted tubes.
- Andrew
Unread 13-09-2012, 09:07
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Exactly what I was thinking.
Hold on to your shirts kids, here comes some physics:
Force = mass * acceleration
(whew!)
The heavier rings will have a greater force of impact if allowed to fall the same distance as the lighter rings, and if they hit the same spot. Calculating the actual force of impact takes the rest of the kinematic equations (as well as some experimentation to figure out distance of deceleration & duration of impact. In any event, more force = more spring extension or more cantilevered polycarbonate sheet deformation.
As for the rules -- I don't believe springs are allowed. However, surgical tubing and deformation of polycarbonate are allowed.
GitHub
Unread 13-09-2012, 15:33
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
A really popular method in my team is a spring.
If your grabbing mechanism, say, a claw, is attached to a spring that's hooked up to a stationary point at the top of your bot, then:
1) When the claw grabs a regular ring, it will expand by X centimeters.
2) When it grabs a weighted ring, it will expand by 3X centimeters.
You'll be able to see it very easily.
Unread 11-10-2012, 22:11
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Consider the reality that only a limited number of successful trips between the dispenser and the scoring rack are possible in the 2+ minutes of driver control.
If a reasonable amount of rings are not scored, of what real value will the heavy rings be? Can you afford to wast one scoring cycle to place one or two 20% bonus heavy rings? We decided that only if two rings were adjacent on the dispenser pipe and could be taken together, would they be worth the time it takes to waste one cycle of scoring two rings at the rack.
The odds for a pair of heavy rings being randomly placed adjacently on the dispenser bars is fairly low based on my rough estimation. So, how many scoring rings can be dropped to the floor in order to get a pair of heavies together in order to justify the trip to the corner?
Our team concluded that unless we could first establish at least 30 pts. worth of row or column scoring bonus points, that going after heavy rings was a greater waste of our scoring possibility time, than what a heavy ring or two scored in the corner would yield.
However, having a partner can also score rings quickly and one bot that can sort out the heavy ones and put them back onto the free space of one dispenser bar, so so one bot can then take pairs of heavies over to the corner, this could prove to be a powerful scoring strategy.
-Dick Ledford
Unread 12-10-2012, 08:59
altf4's Avatar
altf4 altf4 is offline
FTC #6082
altf4 is an unknown quantity at this point
I was under the impression that just the ring scores were multiplied by the corner rings, not line scores or any other ring bonuses. We are thinking that unless the other bot can quickly score lots of 30's, the corner bonus may not be worth it.
Unread 12-10-2012, 10:45
JesseK's Avatar
FRC #1885 (ILITE)
To the contrary, let's say a team decides to forgo the top row completely in lieu of a simpler robot for a December competition. This is a stark reality for many FTC teams. The scoring analysis boils down to how many 'extra' points would going for the top row give if it were designed for instead of adding a weighted ring detector. The analysis would also have to break down how many weighted rings could be scored in the same amount of time it took to own the top row, let for now let's assume a 1:1 tradeoff.
  • If the bottom 2 rows are filled/owned and 1 weighted ring exists on the corner peg, then the score is 126 (assumes 1 ring per peg)
  • If the bottom 2 rows are filled/owned and 1 top row peg is filled/owned and no weighted rings on the corner peg, the score is 180.
  • If the top 2 rows are filled/owned and no weighted rings are in the corner, the score is 135.
An easy argument to make is that for two equally-practiced teams, a team which scores the bottom two rows will be able to score faster than a team that scores the top two rows. Thus the team that scored on the bottom first will have more time to place that last ring on top.
On the surface, this seems like a no-brainer -- go for the top row. Yet there are underlying tradeoffs that may allow the low-peg team to pull ahead in most situations:
  • Their lack of adding complexity for the top row gives them more time to pull of a complex autonomous routine, netting them the ability to score their own and their partner's ring (+50).
  • The extra practice time with the intention of going for weighted rings allows them to score more rings overall, including more regular rings than a team which goes for the top row and weighted rings (+10-20 points)
  • There will be plenty of opportunities (at least one per match per field) for a double-weighted ring score to occur. When it does happen, the team which specializes in weighting will be prepared for it and have practiced it multiple times (+42 points)
  • The simple fact that the weighted ring adds an entire other place on the field on which to score (a totally different zone!) means defense will have to guess where to go next. This would be particularly devastating to that top-level team when they're trying place that last ring on top in that VERY predictable spot. (20-40 point differential per match)
  • Match to match, if the weighted ring detector fails then in most designs* it isn't catastrophic to run a match without it. A top-tier lift adds complexity versus a mid-tier lift, thus is more prone to failure over the course of an entire season. With a lift failure it would be catastrophic to run a match without the failed system. (probably only 1 match outcome affected over the entire season)
*Get creative! One doesn't NEED gravity to detect the weighted rings, as my students were quick to point out to me.
GitHub
