Go to Post the best way to make things most unfair is to have different rules for different people. - Jack Jones [more]
Unread 09-09-2012, 21:35
protoserge's Avatar
protoserge protoserge is online now
AKA: Some call me... Tim?
Re: pic: First attempt at Sheet Metal Chasis please give advice to help me improve
How will you mount other components to that chassis? There doesn't appear to be a lot of room to affix any additional structure? Have you considered a standard mounting hole pattern?
Additionally, are you familiar with the SuperShifter as a whole (maintenance, accessibility, access of internals)? The transmissions should be removable in a few minutes. I can speak from experience here: it takes The RoboBees over 20 minutes to remove the transmissions at a moderate pace (that is really not good).
To your above mention of omni wheels, I'm curious why you would consider them in a 6WD drivetrain (from a design perspective). In my experience, the 6WD is built for robust pushing power and stability, I would think that omniwheels would discount pushing power and ability to hold ground in a pushing match.
Not a bad first design. It's definitely a good start. Keep iterating.
Originally Posted by SuperNerd256 View Post
Put some braces between your transmissions, or something to stiffen the frame. It looks like I can warp it in any which way I'd like with a little impact.
Any reason for using FIRST wheels? Plaction, Colson, etc are all really nice wheels, and provide a ton more grip than the FIRST wheels.
Other than that, nice design. Keep up the good work.
Depending on the design of the superstructure, a lot of bracing may not be required for this drive platform. You can gain significant stiffness from a structure that mounts to this chassis.
I definitely agree with the bracing from one of the transmissions to the other, however.
