Go to Post I've determined that the only thing rumors are good for is putting your knickers in a twist. - JaneYoung [more]
Unread 09-09-2012, 01:18
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: Andy Mark Supershifter with Pneumatic shifters
Originally Posted by Coffeeism View Post
Well for a 20PSI 1/2 inch cylinder you would get about 4.5 lbs. Here's a random solenoid close to spec that is about 2.2 lb push, 6.6 lb pull. Could probably alter the spring to even out the force?
This solenoid is one-directional, push only. The spring return is only minimal to return the armature to the retracted position when de-energized. It is also intermitant duty, which means it can be energized no more than 50% of the time without overheating. A shifting actuator must maintain force in either direction at all times. This is one reason an air cylinder is well suited to the job. A continuous duty solenoid of this same wattage would have about 1/3 the force.
Unread 09-09-2012, 01:34
jspatz1's Avatar
AKA: Jeff
Originally Posted by Ravage457 View Post
What diameter pin should I use after I had drilled it out?
Hmmmm....I think the solenoid shifter is my next project, thank you for the input and advice
What teams had used this solenoid set up?
3/32.
As I mentioned this is the first year solenoid actuators have even been permitted on a FRC robot, so there is no history of them being used for shifting that I know of. If someone successfully did this in 2012 I would be curious to hear about it.
Unread 09-09-2012, 20:33
Ravage457's Avatar
Ravage457 Ravage457 is offline
Ravage457
AKA: Jesus Jurado
FRC #0457 (Grease Monkeys)
Ravage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to behold
Yes i agree with jspatz1 about this conversaion, but im also wondering about this solenoid shifter, if anyone has use this setup,please feel free to add to this conversation, i see the pros and cons about using pneumatic shifters......what are the pros and cons using solenoid shifters
FRC Team 457 "04-"05,"07-"08,"11-Present
Lead Drive Train Mentor/Drive Team Head Coach
2014 Dallas Regional Winners:#1 Alliance-Captain: 148, 1st:359, 2nd:457
2013 Hub City Off-Season Event Winner:#1 Alliance- Captain: 457, 1st:3366, 2nd:1817
2012 Alamo Regional Winner:#3 Alliance- Captain:231, 1st:1477, 2nd:457
2012 Ozark Mountain Brawl Winners:#8 Alliance - Captain:1986, 1st:1987, 2nd: 457
2012 Texas Robot Roundup Winners:#1 Alliance- Captain:118, 1st:624, 2nd:457, Backup:4332
Unread 09-09-2012, 20:44
FRC #1836 (MilkenKnights)
pros: less weight(no compressor and tanks)
cons: slower
Unread 09-09-2012, 21:37
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Originally Posted by jspatz1 View Post
All my comments are assuming a pneumatic system is already available. Comparisons to air shifting should be done at 60 psi, not 20 psi. The solenoid wattage which was allowed in 2012 would not begin to approach the force of an air cylinder for a continuous duty solenoid. Keep in mind that solenoids are one-directional, and their "rated" force exists only in a small fraction of their total stroke.
Why should it be 60 PSI? Shouldn't it be closer to the actual force required?
Our own shifters we had, we've always run at 20 PSI for the solenoid valves sake. I was under the assumption that it took less force than the 12 lbs to shift but I could be wrong about this as I have no experience with the super shifters.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 09-09-2012, 21:51
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
The own shifters we had we've always run at 20 PSI for the solenoid valves sake. I was under the assumption that it took less force than the 12 lbs to shift but I could be wrong about this as I have no experience with the super shifters.
We run our SuperShifters at 20 psi as well without issue. 60psi shifts with 27 lbs of force (force = pressure*area, where the Bimba 040.5-DP has a 3/4" bore).
Another setup that I've heard of is using a window motor coupled to both transmissions with a spring setup to engage the gear if it is not lined up during the initial gear change request. I do not know what team had this setup, but it is definitely worth researching some more as it could offset the weight of a pneumatics system, even those with pvc air reservoirs.
Unread 09-09-2012, 21:55
AdamHeard's Avatar
Lead Mentor
Originally Posted by stinglikeabee View Post
We run our SuperShifters at 20 psi as well. 60psi shifts with 76lbs of force (force = pressure/area).
Force = Pressure * Area. Much smaller force there.
Unread 09-09-2012, 21:57
David Doerr's Avatar
David Doerr David Doerr is offline
FRC #4478 (Materia Oscura)
David Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud of
That would be Team 67...
Unread 09-09-2012, 21:59
protoserge's Avatar
That's a clue that I should go to bed.
Fixed for posterity, thanks.
Unread 09-09-2012, 22:32
jspatz1's Avatar
AKA: Jeff
Pneumatic solenoid valves of the type used in FRC are internally piloted valves, which means the pressurized supply air is used to actuate the valve spool, not the solenoid. The solenoid is very small and only opens a tiny port to trigger the pilot air. Such valves have a minimum pressure that will allow it to operate, usually around 30-40 psi. So they actually prefer a high pressure and only function reliably when it is sufficient. So a note to teams: If you have a valve that is not responding when you are certain it is getting a proper electrical input, and you are using low pressure, chances are the pressure too low for the valve to operate.
Unread 09-09-2012, 22:40
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Right, and the minimum pressure for the valve we were using was at 20PSI. For me, that's not a good reason to say that you need to generate the same force as a 60psi 1/2" piston with a push/pull solenoid to make the thing work.
Kevin Li
596 - Sciclones
