Go to Post Sleep... what is this sleep you speak of? - Choi9111 [more]
Unread 13-01-2003, 17:19
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Re: NO OTHER DEVICES
Originally posted by tenfour
I THINK THERE IS A RULE THAT SAYS NO ADDITIONAL PNEUMATIC DEVICES......THAT MEANS NO VACUME PUMPS!!!!
GET IT OUT OF UR HEAD!!
-SIR STATE THE OBVIOUS ALOT
WHO SAID YOU NEED A "VACUME" PUMP TO MAKE A VACUUM? I CAN THINK OF AT LEAST 5 WAYS TO MAKE A STRONG VACUUM THAT DOESN'T REQUIRE THE USE OF A RESTRICTED PNUMATIC DEVICE.
And do you like being talked to in all caps? CAPS ARE THE EQUIVLANT OF SCREAMING IN TYPE. Would you want to be screamed at? I know I don't like to be, try and use proper capitalization or no capitalization at all.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
pic: Another unsed stacker, wings down CD47-Bot Robot Showcase 11 30-04-2003 21:36
how many of u actually used the stacker if u had one? HolyMasamune General Forum 21 14-04-2003 13:12
A stacker repents... Jason Haaga Rules/Strategy 24 03-03-2003 19:10
Image Discuss: Team 753 Working on the Stacker CD47-Bot Robot Showcase 2 22-02-2003 01:05
Next Question - Check Valve archiver 2001 7 23-06-2002 23:18
