Go to Post FIRST may very well be the healthiest drug on the market. - Herodotus [more]
Unread 10-09-2012, 00:12
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
pic: Team 3647: Gearbox
Unread 10-09-2012, 00:23
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Re: pic: Team 3647: Gearbox
That's a beauty, but it's an absolute beast. You certainly won't have to worry about breaking it. If you want to cut some weight, you could use much smaller gears and axles, especially for the first 2 stages.
Jason
Unread 10-09-2012, 00:33
Mk.32's Avatar
AKA: Mark
The first stage is actually a plastic [Delrin] gear from WCP. Also all the other gears are aluminium so they don't weigh that much to begin with, when I get my hands on some 7072 3/8 Alum Hex we will be using that as well in place of the 1240 steel shafts currently in the box.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 10-09-2012, 06:50
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Looks great What's the overall weight?
Unread 10-09-2012, 13:07
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
With the RS 540 mounted on this, as shown in the image, it should be able to produce the following, assuming ~ 85% efficiency:
Stall torque = 1200 oz/in. = 6.3 ft/lb
Free Speed RPM = 466.
If an RS 550 were used, those numbers would be:
11.34 ft/lb and 536, respectively.
How many uses could I find for a little beasty like this? Let me count the ways.......
Unread 10-09-2012, 14:25
Mk.32's Avatar
AKA: Mark
We are actually planning to switch to a 550, the 540 was just the only motor I could get to test this.
This box is running our tower pulleys, there is an machined pulley that fits on the shaft and is held with a set screw, hence the flat on the shaft.
According to sw it weighs around 1.8lbs, I haven't actually put it on a scale yet.
Unread 10-09-2012, 15:09
protoserge's Avatar
Pfft. There's more weight to be removed Not bad - was that including the motor?
Unread 10-09-2012, 16:25
Mk.32's Avatar
AKA: Mark
Yes it was including the motor.
Yeah there is definitely some room for weight reductions. Also probably going see about using the plastic FP gears.
Unread 10-09-2012, 17:23
My sense of scale is way off, I thought that was a 700 series motor. What size are the shafts?
Jason
Unread 10-09-2012, 18:45
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
Given the reduction of your gearbox, and how much torque you have at the shaft, I would extremely worried about using a set-screw to transmit power to the pulley. I wouldn't expect it to take more than a few matches for that set screw to start slipping (because of your high reduction I'm assuming this gearbox is being used in a high load application).
The best way to transmit power to and from a shaft is to use hex shaft and hex broached components. I can't see into your gearbox too well, but given that those are WCP gears I'm assuming that your output shaft is hex that's been lathed down to 3/8. I would suggest that you redesign your plate to accommodate a 1.125 OD bearing for your output shaft and use an AndyMark 3/8hex oversized bearing. Or if you don't want to redo your plate and still use that 7/8 OD bearing then I would suggest you mill a keyway into your shaft and broach a keyway into your sprocket, it wouldn't be a good as using hex shaft but it would be much stronger than it currently is.
Edit: I just noticed that you were using WCP's new 24DP delrin gear, where'd you get your 24DP pinion? The only place iv'e found to get a 24DP pinion that isn't brass in to buy SDP-SI carbon steel pinion wire, is that what yours is?
Unread 10-09-2012, 18:58
From their facebook page: It is a pinion from the BB CIM-u-lator. (I asked last night)
http://banebots.com/p/S24P-GMC1-32
Unread 10-09-2012, 19:32
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
True, set screws should be avoided normally in high load applications, but I wouldn't exactly consider belt pulleys in a tower to be an extremely high load application.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 10-09-2012, 19:45
I just looked at their robot and you're right, it's not a high load application, but it's still more than I would trust a set screw for.
Unread 10-09-2012, 20:03
Mk.32's Avatar
AKA: Mark
It's a 500 motor and all the shafts are 3/8 Hex with the ends lathed down to 3/8 round.
The reduction was mainly for low speeds not torque. This runs the pulleys on the tower which is not a high load application, we actually used set screws on the competition robot this season and never had issues. With a flat in the shaft and some lock loctite on the screw it's fine for lighter loads.
Unread 10-09-2012, 20:58
Mk.32's Avatar
AKA: Mark
Sorry about the double post but I mis read this before, the weight of the box according to sw is actually 1.08 lbs not 1.8.
