Go to Post being surgically altered to have two right hands is a big commitment, but if you wanna drive, and drive well ..... ! - KenWittlief [more]
Unread 10-09-2012, 22:56
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
Re: pic: Team 3647: Gearbox
Originally Posted by MICHAELABICK View Post
Is there a reason you prefer the 1.125 OD bearing over this one: http://www.andymark.com/product-p/am-0439.htm ? I doubt they are going to be experiencing 40 lbs radial on that bearing.
Without knowing exactly how that shaft is loaded I wouldn't suggest using the 7/8 OD bearing. If they knew that the shaft was well bellow 40lbs load they could use the 7/8 OD bearing, but it's not difficult to design around a 1.125 OD bearing and bearings are not somewhere to cut corners on, I would never use that 7/8 OD hex bearing on a cantilevered output shaft.
