Go to Post The name of the game will be "Conjunction Junction". The robots will be tasked with hooking up words and phrases and clauses. You're welcome. - Travis Hoffman [more]
Unread 10-09-2012, 21:52
FRC #1836 (MilkenKnights)
Re: pic: Team 3647: Gearbox
Originally Posted by Adrian Clark View Post
Given the reduction of your gearbox, and how much torque you have at the shaft, I would extremely worried about using a set-screw to transmit power to the pulley. I wouldn't expect it to take more than a few matches for that set screw to start slipping (because of your high reduction I'm assuming this gearbox is being used in a high load application).
The best way to transmit power to and from a shaft is to use hex shaft and hex broached components. I can't see into your gearbox too well, but given that those are WCP gears I'm assuming that your output shaft is hex that's been lathed down to 3/8. I would suggest that you redesign your plate to accommodate a 1.125 OD bearing for your output shaft and use an AndyMark 3/8hex oversized bearing. Or if you don't want to redo your plate and still use that 7/8 OD bearing then I would suggest you mill a keyway into your shaft and broach a keyway into your sprocket, it wouldn't be a good as using hex shaft but it would be much stronger than it currently is.
Edit: I just noticed that you were using WCP's new 24DP delrin gear, where'd you get your 24DP pinion? The only place iv'e found to get a 24DP pinion that isn't brass in to buy SDP-SI carbon steel pinion wire, is that what yours is?
Is there a reason you prefer the 1.125 OD bearing over this one: http://www.andymark.com/product-p/am-0439.htm ? I doubt they are going to be experiencing 40 lbs radial on that bearing.
Unread 10-09-2012, 21:53
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Originally Posted by MICHAELABICK View Post
Is there a reason you prefer the 1.125 OD bearing over this one: http://www.andymark.com/product-p/am-0439.htm?
From AndyMark: "This is a light weight bearing, as it cannot handle over a 40 pound radial dynamic load "
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 10-09-2012, 22:56
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
Without knowing exactly how that shaft is loaded I wouldn't suggest using the 7/8 OD bearing. If they knew that the shaft was well bellow 40lbs load they could use the 7/8 OD bearing, but it's not difficult to design around a 1.125 OD bearing and bearings are not somewhere to cut corners on, I would never use that 7/8 OD hex bearing on a cantilevered output shaft.
Unread 11-09-2012, 08:11
greasemonkey's Avatar
greasemonkey greasemonkey is offline
Truss me I'm a Doctor
AKA: Fred Parker, fredword, fredwardo, phred, frederick
FRC #3467 (windham windups)
greasemonkey is an unknown quantity at this point
think about the power out put if it were a cim in there
Unread 11-09-2012, 09:02
Andrew Lawrence
Posts: n/a
5310 rpm (1/36) = about 147.5 rpm output (not including efficiency, etc).
No need to go that fast for most applications.
Unread 11-09-2012, 10:11
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Originally Posted by Mk.32 View Post
It's a 500 motor and all the shafts are 3/8 Hex with the ends lathed down to 3/8 round.
The reduction was mainly for low speeds not torque. This runs the pulleys on the tower which is not a high load application, we actually used set screws on the competition robot this season and never had issues. With a flat in the shaft and some lock loctite on the screw it's fine for lighter loads.
We fell in love with 3/8" hex last year, well, I did anyways. What is the purpose of lathing the end to 3/8" round?
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 11-09-2012, 10:18
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Nice looking gearbox!
I have suggestion: the two 15:45 reduction clusters are not, strictly speaking, good design practice. Any one 1 tooth on the 15 tooth gear will contact the same 3 teeth on the 45 tooth gear. This isn't good for gear life and long-term efficiency. Using a 44 or 46 tooth gear instead of a 45 would result in more even gear wear.
Of course this probably isn't a big deal for FRC given the short lifespan of most parts and your intended low-load application.
Unread 11-09-2012, 11:07
Brandon Holley's Avatar
Sisk- not to speak for the OP...
...but in the past, we have turned 3/8 hex down to round to utilize regular round bearings. Obviously we prefer to use hex for all power transmission where we can, but it has happened in the past.
One specific example was in our lift for 2010. The lift gearbox utilized a CIM through a series of reductions to spin a pulley to wrap a line which pulled us up. The radial load was most certainly above 40 lbs, which was not a known issue at the time for the AM hex bearings. We destroyed a set of them at one of our regionals, and before the next competition we changed the hex bearings to regular round bearings, subsequently requiring us to turn down the end of the shaft and mill a keyway.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 11-09-2012, 11:34
Chris is me's Avatar
AKA: Pinecone
Another small benefit for turning the ends of a hex shaft down to round is that, when you sandwich such a shaft between two plates, you don't need any other hardware to retain the shaft between the plates. A straight hex shaft would need something like snap rings on the outside to be held in place, while a hex shaft with rounded ends would hold itself between the bearings just fine. A minor advantage, but useful nonetheless.
Unread 11-09-2012, 13:35
Mk.32's Avatar
AKA: Mark
Here's a bit of insight of what I went though designing this:
For the stages I turned the shaft down to 3/8 round at the ends so when we used a round bearing they shaft would be sandwiched as stated above and stay in place, which worked out nicely since I didn't need to put in any eclips or collars. Also the 7/8 hex bearing has a very poor loading performance for this gearbox it would have been fine but in general getting good cheap 3/8 round bearings are easier.
The output shaft was also turned down to 3/8 round so I can interface it with our pully https://sphotos-a.xx.fbcdn.net/hphot...84491030_n.jpg.
We don't have hex broaches [wish we did] so just using an set screw on a flat on the shaft was fast and easy. Also since this is mostly a low load application the set screw will be fine.
For our shooter we turned down a 3/8 hex shaft and milled in a key way so we could interface with the 3/8 AM Wheel hub.
Unread 11-09-2012, 14:04
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
We don't have hex borching [wish we did] so just using an set screw on a flat on the shaft was fast and easy. Also since this is mostly a low load application the set screw will be fine.
It sounds like you have access to a decent assortment of machine shop tools. If you have access to a surface grinder, a lathe, a Dremel, and an old worm out HSS end mill you can make your own hex broach. Here's how you can make a 1/2" hex broach:
1. Acquire a few inches of 1" or larger hex stock. Drill and ream a 5/8" hole through it, and add a set screw hole.
2. Take an old 5/8" HSS end mill. Cut off the flutes. Mount the shank into the hex tool holder above with about 1" sticking out.
3. Clamp down the hex stock onto the table of the surface grinder.
4. Take a light pass on the surface grinder.
5. Rotate the hex stock to the next face.
6. Repeat steps 3-5 until you have ground the end mill shank into a 1/2" hex profile.
7. Mount the end mill shank into a lathe with the hex profile facing outwards.
8. Put a cutoff tool in your Dremel tool. Turn on the lathe and Dremel, and hold the Dremel tool perpendicular to the lathe. The objective here is to cut a concave dimple with sharp edges into the hex profile.
9. Congrats, you now have a cheap hex broach that will work in soft materials like aluminum or plastic.
You can substitute in different sizes above to make 3/8", 7/16" or other size broaches.
Art Dutra IV
世上无难事,只怕有心人.
Unread 11-09-2012, 14:25
Mk.32's Avatar
AKA: Mark
Wow I never thought you could do that. Might give it a try
Instead of using a 5/8 endmill would just a stock of Tool Steel work?
Is just getting a good hex on the tool just a lot of time and patience on the grinder with careful measuring?
Unread 11-09-2012, 15:33
artdutra04's Avatar
Tool still would work just fine. When I did this a few years ago, I used an old end mill because it already had a flat spot to set screw against and because there was a box of end mills with chipped/broken flutes available.
Grinding out a good hex profile was fairly fast to get it close, then slow and careful to get it right. If you have an indexing head, then that would be even more accurate than using a piece of hex stock as a tool holder for grinding the hex profile into the end mill/tool steel. The surface grinder I had access to did not have the standard machine slots to mount an indexing head to, but rather had a smooth surface magnetic chuck, which is why I just used a piece of 1" or 1.5" steel hex stock as the tool holder.
Art Dutra IV
世上无难事,只怕有心人.
Unread 11-09-2012, 16:05
Aren_Hill's Avatar
Build Nifty Things
Arts method can also work on softer steels, I made one and broached 8 steel sprockets from SDP with no visible signs of wear.
I was also lucky enough to have an indexer I just stock on the magnetic chuck.
A guy who likes robots.
