Go to Post I've been busier than a hog farmer at feedin' time. - Andy Baker [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 31-12-2002, 01:29
Mike Iantorno's Avatar
Mike Iantorno Mike Iantorno is offline
#0783 (Mobotics)
Mike Iantorno is an unknown quantity at this point
Send a message via ICQ to Mike Iantorno
Mobotics.ca
Continuing along the line of shameless self-endorsement, Mobotics.ca is up and running. Its a little hard to run on low res, lacking some content, and in desperate need of a intro page but asides from that its DONE. Comments and Criticism are welcome.
Unread 31-12-2002, 01:35
Gope Gope is offline
#0016 (Bomb Squad)
Gope is on a distinguished road
Not bad
im pretty big into website interface design, and i must say, u've done quite a nicee job, altough the menu dosent fit into the interfacee well.
Consider the following:
trash the idea of an into-page....they just annoy people and are stupid
get rid of the menu start-up animation....it wastes people's time and annoys them, try only using animations that do not limit site functionality
perhaps redo the menu...it dosent go well with the rest of site
other than that, ,u've done a very nice job
College and its wonders. First year and alot of other FIRSTs.
Unread 31-12-2002, 01:54
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
I always like a nice Flash menu. I think it goes fine with the rest of the site, and 'cause the opening animation is on a mouseover, it isn't really in the way. I'd totally keep it. Just one thing... the gear animation... it looks like you did a bitmap trace or something... I'd suggest tracing over the bitmap with vectors by hand, and then replacing it in the tween. And yes, the into-page is annoying. Otherwise a very clean layout. Nice looking work.
If you want to see what too much animation is, see this: http://robodox.tripod.com It's a layout I made a while back that the team never tried to use for the official website. I need to make one for the official site one of these days...
Unread 31-12-2002, 12:24
#0783 (Mobotics)
I kinda need the intro page, unless we get around to figuring out how to use javascript to auto-redirect the user to the correct resolution site.
Also, we got someone making a no flash, no frames, low res version of the site for people with "less spiffy" computers. That'll replace the low res site thats already there.
And thats one trippy site layout Suneet, which the clamp/box animations and all. Thats some nice flash, but as you said, a bit excessive.
Unread 31-12-2002, 13:27
Happy Birthday! rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Very spiffy looking. My only gripe (other than the intro page) is that clicking on the links opens the new site inside your frames. You can fix this with a target=_top inside the link tags. Or, if you'd prefer to open in a new window, the tag is target=_blank
If you're interested, the necessary JavaScript is:
<script language="JavaScript">
if ((screen.width>=HIGHRESWIDTH) && (screen.height>=HIGHRESHEIGHT))
window.location="my-high-res-page.html";
else
window.location="my-low-res-page.html";
</SCRIPT>
Just replace my-high/low-res-page.html, and HIGHRESWIDTH/HEIGTH with your values and you should be good to go.
Unread 31-12-2002, 13:36
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
It looks great, but you know what? I'd consider trying:
1)to speed up the menu animation; i almost fell asleep waiting to access info (either that or bypass the animation with a click)
2)to just have one version of the site (i.e. no highres/lowres; it'll save everyone a bit of trouble
3)to get rid of the splash screen, espcially if there's only one version
4)to watch those frame targets; toronto.com for example is opening in the main frame
5)to change the small image below the email addresses that isn't rendering properly in my browser
Unread 01-01-2003, 13:34
#0783 (Mobotics)
Booya, I'm finally getting some good contructive criticism. I'm going to do a massive site overhaul before kickoff, so I'll try implementing a lot of that stuff before then.
Unread 04-01-2003, 22:54
HFWang's Avatar
HFWang HFWang is offline
AKA: DarkWulf
#0115
Team Role: Webmaster
HFWang will become famous soon enough
Send a message via ICQ to HFWang Send a message via AIM to HFWang
Just an FYI for you... in mozilla/phoenix (I'm running 0.5 of phoenix) those pretty flashes don't work.
http://www.alistapart.com/stories/flashsatay/
details a solution. its very hackish... but whatever.
or you could drop flash because its a binary, propeitary thing, completely against the whole notion of the internet to begine with, but i doubt it.
Unread 06-01-2003, 19:50
Taiguy Taiguy is offline
VRC #0122 (NASA Knights)
Taiguy is an unknown quantity at this point
nice stuff, our school's server has been down for a while and admin's kinda slackin off so we're still without a home on the internet.
the menu animation isn't over excessive, but you might want to think about reworking the interface so that it fits in with the rest of the site. The grey doesn't really go along with the blue/orange (great combo) btw.
-tai
Unread 06-01-2003, 22:05
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
I'm using Opera 6.0 in Linux and the vertical bar on the right side of the main content frame or whatever looks out of place. With closer inspection, it looks as though it's supposed to be that way...I'd think it would look better just straight down...
And the menu animation is a tad long...nice, but long.
Otherwise, beautiful site. One question...did you code the HTML, make the images, and make the flash? Because it looks great. Love the color scheme. I'd like to see your bot sporting a nice paint job with those
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 06-01-2003, 22:11
WFM, trunk 2003010108
Maybe you should try a new build or newer Flash, because, it seems to be fine here.
Unread 13-01-2003, 18:41
HFWang's Avatar
AKA: DarkWulf
#0115
how embarrassing, it only doesnt work in phoenix. its fine in mozilla...
I am forced to conclude that phoenix simply hates me.
Unread 14-01-2003, 22:42
#0783 (Mobotics)
Well, I did the html, and I designed the graphics. The colour scheme was brainstormed by the whole media team. Can't take credit for the Flash though, Kwun did all of that.
And yeah, we're thinking of doing the bot in Orange and Blue. We chose the orange because it was really "loud", and we wanted to stand out at the competition. Wait until you see the T-shirts....
