| Thread Tools |
Rating:
Display Modes |
#16
Re: [FTC]: FTC Expands the kit of parts option for next season
It also seems to me that their shafts are different sizes than Tetrix, which means I hope to god they make shaft couplers. Thats one thing that Tetrix even needs to make. But Tetrix and Matrix both have their major and subtle differences. Tetrix not needing nearly as much work as Matrix to make a robust robot. But Matrix I have a feeling will make things smaller. Overall next year shall be fun. - Andrew P.S. 67 Team H.O.T. did a 1/16 inch sheet metal drive train this year. Almost made it to Einstien. 1/16 is plenty strong, if done correctly. |
#17
I think these parts are going to be used for the more intricate systems on FTC bots. Tetrix will be used more for chassis, and the heavy-duty stuff. And think about it. Why would FTC use these parts if it weren't because of next years game? Perhaps there are going to be more precise manuevers we have to perform that Tetrix can't handle.
#18
We spent some time at the booth talking with the Matrix people. Their system is based on 9V not 12V so even though the parts might integrate mechanically (Matrix is based on an 8mm grid while tetrix is based on a 32mm grid) the electrical components would likely require a separate set of wiring for power.
I was told that the 9v motors are slightly less powerful than the tetrix 12V motors we are currently using. They also have built in encoders. I would be interested in seeing what options we have to connect multiple motors in parallel on a single circuit and control them with a single shaft encoder the way we do with our tetrix motors. |
#19
Can someone put me to speed here please.
Lego Education and Tetrix are no longer working with each other (or so I heard), so Matrix will be replacing Tetrix? |
#20
No Matrix is simply an addition to the FTC competition legal parts. As far as I have heard. Mainly will be used by international teams at first and then slowly introduced to the state side competition.
Thats what I have heard. - Andrew |
#21
I had not compared the Tetrix and Matrix metal gauge until this morning when I had been asked to measure after casual observations and assumptions and posting in another thread here on CD.
I've got both in house and have used them both now for summer robotics camps with no real issues. Big difference is in the angle beam and not much difference IMHO for the flats and corner connectors (1/64 or 0.015625) Angle Tetrix 0.12500 (1/8) Matrix 0.06250 (1/16) Flat Plate Tetrix 0.078125 (5/64) Matrix 0.06250 (1/16) Corner Connector Tetrix 0.078125 (5/64) Matrix 0.06250 (1/16) U-Channel Tetrix 0.078125 (5/64) The beauty of the expanded FTC raw materials list is that one can purchase aluminum stock in a couple of sizes if you really need what one kit has verses the other. |
#22
Drive down to Northern Virginia to chat with me, or ask some of the many Maryland groups using Vex parts to show you how to build a sturdy Vex bot. There is absolutely no doubt that the kit's structural parts work just fine. The thousands of teams that use Vex equipment successfully in VRC, in Best, and for other purposes, are prima facie evidence that your assertion is just plain wrong. I have personally used both Tetrix and Vex parts and have a pretty good grasp of their major similarities and differences. As for the assertion that a 52Lb bot (made from anything) might damage a bot made out of Vex structural materials. Well DUH. A 52 Lb bot hitting a 15 Lb Tetrix bot hard is also likely to damage the 15 Lb Tetrix bot. Similarly, a very large car smashing into a very small car will probably inflict more damage than it suffers. Also, an M1 tank hitting a car would destroy the car and probably not suffer any damage at all. However, that's not the point, and neither your example, nor these I dreamed up are evidence that supports your thesis. Blake PS: I'm glad to see that FIRST is expanding the parts teams can easily incorporate into FTC bots. Last edited by gblake : 06-09-2012 at 20:37. |
#24
There is plenty of opportunity in the N. VA and MD region for motivated students or mentors to particpate inspirational robotics competion programs (or 4H's vendor-neutral non-competitive program) that use parts made by Vex, Tetrix and other suppliers. And all interested parties should be encouraged to look at all of the options and find the one that best suits their situation. There should not be sniping and bad-mouthing by participants in any of the programs. Instead there should be support, encouragement, and COOPERTITION (with an extra emphasis on the cooperation half of that ethos). I have crunched some numbers on the student population in the region, and can assure you that because Robotics/STEM participation in the area is soooo far below what almost anyone would want, anyone who wastes precious time bad-mouthing any program or product that might be a source of inspiration for additional students, doesn't "Get it." I think I can quote some FIRST luminaries who have spoken out on the subject, if you don't take my word for it. Blake Last edited by gblake : 06-09-2012 at 20:35. |
#25
Do Matrix products exist?
Their website -- http://matrixrobotics.com/products/ -- has very little information about what's going on or what will be available. Our FTC teams compete in December, so if the product isn't available to us right now, we won't use it at all; I just want to make sure I'm not missing anything. |
#26
I can only imagine the amount of calls the sales department are getting ![]() - Andrew |
#27
Matrix needs to, at the very least, update their website so people know that stuff is happening.
#29
From the photos it looks more like 3/32 to me (more than 1/16 but less than 1/8)
TETRIX metal is more than 1/16" maybe 2mm since it is a metric system. Phil. |
