Go to Post No, nothing secret unless you include the following: will it work?, can it be driven and will it release the balls. - twolf [more]
Unread 12-09-2012, 01:27
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
2012 Van Door Motor Circlip Goove
Hi, does anyone know what the diameter of the circlip groove in the 2012 van door motor is?
Unread 12-09-2012, 01:44
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: 2012 Van Door Motor Circlip Goove
There was a van door motor in the 2012 kit?
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 12-09-2012, 10:44
DampRobot's Avatar
Physics Major
AKA: Roger Romani
No, he's probably talking about one salvaged from a scrap yard. Usually, the groves are standard sizes based on the diameter of the shaft. If you know the diameter of the shaft, you can find out what e-clip or c-clip you need to use. Also, the depth and diameter of the groove could easily be measured with a pair of digital calipers.
-Plutarch
Unread 12-09-2012, 11:50
Generator of Entropy
FRC #2973 (The Mad Rockers)
Yes there was, available from FIRST Choice
Unread 12-09-2012, 11:59
Technical drawing of the Van Door from previous year's kit; I think the interfaces are the same for the ones they supplied last year:
http://www.usfirst.org/uploadedFiles...2016640238.pdf
Unread 12-09-2012, 12:10
My B.
James Tonthat
