Go to Post I had so much to say but I dont know how to get it accross -- but to all of you that we were involved with this weekend, thankyou for everything -- we're changing lives, and we truly are moving mountains, in more ways than one. - Jacqui Sutton [more]
Unread 12-09-2012, 08:54
Ravage457's Avatar
Ravage457 Ravage457 is offline
Ravage457
AKA: Jesus Jurado
FRC #0457 (Grease Monkeys)
Ravage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to beholdRavage457 is a splendid one to behold
Suggestion on What to use on battery Terminals
Hello Chief Delphi community
I wanted to ask, what does everyone use to protect the terminals on the battery, do some use electrical tape or shrink wrap? What do you, ladies and gentleman use on your battery terminal to protect or cover them?
FRC Team 457 "04-"05,"07-"08,"11-Present
Lead Drive Train Mentor/Drive Team Head Coach
2014 Dallas Regional Winners:#1 Alliance-Captain: 148, 1st:359, 2nd:457
2013 Hub City Off-Season Event Winner:#1 Alliance- Captain: 457, 1st:3366, 2nd:1817
2012 Alamo Regional Winner:#3 Alliance- Captain:231, 1st:1477, 2nd:457
2012 Ozark Mountain Brawl Winners:#8 Alliance - Captain:1986, 1st:1987, 2nd: 457
2012 Texas Robot Roundup Winners:#1 Alliance- Captain:118, 1st:624, 2nd:457, Backup:4332
Unread 12-09-2012, 09:08
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Re: Suggestion on What to use on battery Terminals
Terminals on the batteries need to be checked often to make sure that they are tight. That is why we use electrical tape instead of shrink wrap.
Unread 12-09-2012, 09:34
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
For our battery terminals, we use locking nuts to help ensure they won't come loose, and some heat shrink. These get checked multiple times per season (beginning of the season and before every competition) to make sure they haven't come loose. If any do (we've only had a couple that have over the past 6 years), we cut away the heat shrink and completely redo the connection (with new heat shrink as well!).
Our feeling is that heat shrink is slightly safer, as it's harder to accidentally remove than electrical tape. That said, there's nothing wrong with using electrical tape, so long as you ensure everything is covered and make sure the tape doesn't start pulling up!
2016: Lake Superior WFFA
Unread 12-09-2012, 09:48
Before using heatshrink we assemble the terminals in a special way. The use of an external tooth star washer between the terminals and the addition of locking hardware will insure that the termination will never come loose. If the terminals cannot move, the hardware (even locking hardware) will not come loose. I am a big fan of keps nuts (lock washer is integrated in the nut) and battery terminals are only one place they are useful. They are available from McMaster.
Unread 12-09-2012, 10:19
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Doesn't that have a negative effect on the electrical impedance of the connection? Do you use any special alloy for the hardware to minimize any potential effects?
Unread 12-09-2012, 10:33
Mentor, LRI, MN RPC
PAR - The nut and bolt aren't involved all that much in the electrical pathway. The electricity will primarily flow from the battery terminal through the lug terminal on the end of the battery connector. This is due largely to the large surface area connection between the two, which makes it a much, much more efficient conductor than going "out of your way" to travel from the battery terminal, through the head of the bolt, down the bolt, into the nut, and finally into the terminal on the end of the battery connector.
True, any time you have conductive materials attached together, all of the materials involved will conduct some electricity. But in this case, it's not enough to make it noticeable. Essentially, you have a current divider circuit, with the two sides of the circuit having significantly different resistances. Play around with that, and see how changing each side of the circuit can change the overall current through the circuit.
Unread 12-09-2012, 10:35
Alan,
While it might add a slight series resistance, the teeth of the star washer bite through any surface crud and oxidation on the lead battery terminal and when tight produce more contact surface than the terminal. AS the hardware tightens on the normal terminal it deforms and produces a cup shape. The ability to keep the terminals from moving is the distinct improvement here. We have batteries labeled as far back 2006 that we use for practice that have no issues with loose terminals.
Unread 12-09-2012, 10:51
Ravage457's Avatar
Ravage457
AKA: Jesus Jurado
Is their a specific size of heat shrink that has to be used?
Unread 12-09-2012, 11:31
Jesus,
It depends on the size of the terminal you are trying to insulate. It will likely be somewhere between 1/2" and 1".
Unread 12-09-2012, 12:34
Mentor, LRI, MN RPC
If you look at the specs for heat shrink, it'll specify an inside diameter both before and after shrinking. You'll want to get some that is big enough to fit over everything, including the nut and bolt, but that will shrink down to a snug fit without splitting. I've seen students use the wrong heat shrink a few times... it looks good, then they put the heat gun on it, and it splits because it tries to shrink too small for the wire it's around!
Unread 12-09-2012, 12:39
Ravage457's Avatar
Ravage457
AKA: Jesus Jurado
Jesus,
Thank you Mr. Al Skierkiewicz for the advice and suggestion
Thanks again Chief Delphi Community for the advice and input, it greatly appreciated, as i have so much to learn
Unread 12-09-2012, 12:42
Ravage457's Avatar
Ravage457
AKA: Jesus Jurado
Thanks Jon Stratis, i will keep that in mind so that it won't happen and end up ripping it
Unread 12-09-2012, 13:41
trilogy2826's Avatar
trilogy2826 trilogy2826 is offline
Mentor - 2826
AKA: Jake Fischer
FRC #2826 (Wave Robotics)
trilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond repute
... it splits because it tries to shrink too small for the wire it's around!
Another couple factors to consider to prevent the nototrious heatshrink split:
1. Buy good heatshrink. The ES200 line from Tyco (http://www.strancoproducts.com/downl...ta%20Sheet.pdf) has an amazing 4:1 shrink ratio and is pretty rock solid
2. When cutting the HS from a longer length, make sure the cut is straight and contiguous. Any aberration along the cut will likely cause a tear. This commonly happens when cutting a larger diameter HS with a pair of side cutters, where you can't cut across the width with one full cut. We typically use a pair of stout scissors or, odd as it sounds, a heavy duty paper cutter (good for getting precise lengths).
Unread 12-09-2012, 15:45
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
This is a quote of an earlier post, but no matter. If you'd need to check your terminals and want to use shrink wrap, I'd suggest clear shrink wrap. I don't have much experience with wiring a robot, but I know that using electrical tape is unreliable because it's not exactly the stickiest tape on the market...
I use it all the time and reccomend it to you!
J Wallace IV
Truck Town Thunder
Just a college student now.
Unread 12-09-2012, 16:00
Mentor, LRI, MN RPC
Trust me, when the terminals aren't tight, you can tell. Just grab the wire near the terminal and wiggle it - if it's tight, it won't move. In this case, IndySam was indicating electrical tape due to the ease at which it could be removed after a terminal was identified as loose, in order to tighten the nut/bolt, and then reapplied.
