Go to Post I think these new rules are making the message coming from FIRST perfectly clear - engineering is about what happens between your ears, not what comes out of your deep pockets. - KenWittlief [more]
Unread 11-09-2012, 20:14
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
From 24V to 12V
Is there anyway to change the 24V Double Solenoids to 12V instead.
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 11-09-2012, 21:03
Re: From 24V to 12V
No,
The solenoid coils are optimized for 24 volts. They might operate at 12 volts but not reliably.
Unread 11-09-2012, 21:24
Camren's Avatar
Camren Camren is offline
FRC #3081 (RoBoEaGleS)
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
Re: From 24V to 12V
Is the 24v solenoid your robot (If so I have a solution) or is it for a electronics project (if so I have another solution)
Unread 11-09-2012, 21:56
Gdeaver Gdeaver is offline
FRC #1640
Re: From 24V to 12V
For SMC solenoids it's just a matter of swapping out the 24 volt coil for a 12 volt one. Imagine it's similar for the KOP solenoids.
Unread 11-09-2012, 22:03
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: From 24V to 12V
You can buy the 12vdc sub-bases from AndyMark and convert the KOP solenoids.
They will work at 12 or 24 volts.
Unread 12-09-2012, 14:28
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: From 24V to 12V
If it is for a FRC bot I would just wire them to use 24v from the distribution board... 24V works a lot better from my experience.
Unread 12-09-2012, 14:57
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: From 24V to 12V
The solenoids are interchangable on the valve and 12v solenoids can be obtained from Festo or a dealer.
Neither 12v or 24v solenoids work better or worse than the other. The coils are designed to provide the same function, and are simply offered in different voltages to match the users needs. There could be some difference in the stabilty or capacity of the 12v or 24v supply on the robot.
Unread 12-09-2012, 15:28
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: From 24V to 12V
Also important to keep in mind... running one of the typical 24V solenoids on a 12V relay can drive you mad trying to debug the problem. The LED's on the solenoid can light up and make it look like it's working, but it won't actually switch anything!
2016: Lake Superior WFFA
Unread 12-09-2012, 17:26
jspatz1's Avatar
AKA: Jeff
Re: From 24V to 12V
A very common problem I have seen often, usually from teams who have followed a KOP wiring diagram using 12v breakout board.
Unread 13-09-2012, 16:53
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Re: From 24V to 12V
We are using it for an offseason robot project.
Unread 13-09-2012, 18:08
Camren's Avatar
Re: From 24V to 12V
Use the 24v pd slot
