Go to Post Sleep? What this you talk about. I never can sleep the night before kick-off. - midway78224 [more]
Unread 12-09-2012, 20:43
wilful's Avatar
wilful wilful is offline
766 Alum & 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
Mounting electronics
This year team 766 is rebuilding our robot for Cal Games with a 1/16 in. aluminum belly-pan to solve our wiring issue and we were wondering how other teams mount electronics to their robot's belly-pan so they can go over the barrier without issues.
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 12-09-2012, 20:51
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Mounting electronics
We mount our electronics to the belly pan similar to what 254/973/968/1477/1538 have done the last couple years. We get 1/8" aluminum and pocket it. Then tap it and mount our electronics to the pan.
You could probably rivet your electronics down. I wouldn't tap to that thin of a pan.
Are you water/laser cutting it? Can you go thicker and pocket?
-RC
R.C.
MadTown Robotics Team 1323
Unread 12-09-2012, 21:00
ttldomination's Avatar
Sunny
One thing that some people recommended (and I look forward to trying) is double sided tape. Some of that heavy duty stuff like this.
Other than that, it's just screws and nuts.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 12-09-2012, 21:08
DonRotolo's Avatar
Back to humble
FRC #0832
We use Velcro and 1/16" lexan. Nice being able to see through from beneath, less chance for sharp edges to conduct electricity, and Velcro makes repairs a snap - we leave an extra few inches of wire, and just pull the offending component to where it's easier to work on.
Unread 12-09-2012, 21:09
R.C.'s Avatar
- Sunny G.
VHB is some really strong stuff. We use it as much as possible. Reduces weight and its quick to apply. Note: do not use on parts you are going to be removing frequently.
-RC
R.C.
Unread 12-09-2012, 21:22
dtengineering's Avatar
AKA: Jason Brett
Why not use thin baltic birch plywood? Wood is about 1/3 the density of aluminum, so you can replace 1/8" aluminum with 1/4" ply and still save weight. If you have to drill an extra mounting hole in the wood, you don't have to worry about conductive shavings getting in your electronics, and you end up with a non-conductive platform, in the event anything comes loose.
As for mounting the electronics, I prefer to use #8-32 nylon machine screws and nuts. We saved over one pound by switching from metal to nylon, and gained the added benefit of having non-conductive connectors.
I'd stay away from the double-sided tape... it works... but any tape sticky enough to actually hold your electronics is likely to be a pain to take apart, or at least leave a mess of tape to clean up when you are done.
Jason
Unread 12-09-2012, 21:23
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
This year we mounted ours on Lexan using velcro and plastic zipties like so.
Unread 12-09-2012, 21:36
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Zip-ties work great for us, or bar-locks for old time CDers.
Unread 12-09-2012, 21:37
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Heavy duty Velcro is amazing for mounting electronics. They come of when you want them to and don't when you don't. It's also easy to change the mounting configuration.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 12-09-2012, 23:56
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Another option I haven't seen here is to use button-head bolts. Stick the bolt in from the bottom, slide the components over it, then put the nut on. This way, the barrier can slide over the bolt head easily, instead of getting caught on a typical socket head.
2016: Lake Superior WFFA
Unread 13-09-2012, 02:02
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
We mount our components using a Pem standoff, nylon allen head screw, unthreaded shoulder spacer with flange. All components are placed using CAD into the belly pan model. We extrude the mounting holes from the components into the belly pan. Then the belly pan is punched. Our belly pan is actually the frame of our chassis. After forming the belly pan we press in the standoffs. To mount the components we screw the parts down using a nylon screw and the plastic washer. Every part is isolated from the metal frame. We cut off the end of the screw to make a flush surface on the bottom.
Here's a picture.
https://picasaweb.google.com/1177698...06907256715874
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
