Go to Post I hope that 50 years from now, FIRST is no longer required. - Lil' Lavery [more]
Unread 13-09-2012, 12:35
karomata's Avatar
karomata karomata is offline
Rebellious Egyptian
AKA: Mo Elhelw
karomata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud of
Re: Castor/Swerve Drive
One of the problems of the drive train your talking about, is that in our appliances, we usually don't incorporate the suspension system the Mars Rover has, so if you found a way to make a dropcenter swerve drive that could tackle bumps like the barrier in the 2012 game, i believe it would become very popular very quickly.
As long as its simple.
Unread 13-09-2012, 13:10
Look up Winnovation's 2010 swerve, all six wheels of it.
It's still the only 6-wheel swerve to compete in FRC. Swerve by definition isn't simple... and adding an extra 2 wheels doesn't help.
Most of the time a 4-wheel (or even 3-wheel) swerve is used, the field is flat. But, this year, several teams used swerve and also crossed the barrier without using the bridges (and then balanced the bridges).
Unread 13-09-2012, 19:02
Secretspy97 Secretspy97 is offline
FRC #1126
Secretspy97 is an unknown quantity at this point
If you DO want to go with Swerve, there are a few decisions you have to make. Namely, motor allocation. You could go with each module steered by its own motor, or you could chain a few together (2 and 2). That's how 1126 did their prototype chassis. That turned into 2 and 1 and 1 for Championships (2 chained together, 2 are independently driven). Now they are working to make it totally independent. I'm not exactly sure what the advantage is to making it all independent, but I'd imagine the modules would rotate faster and easier. It's also heavier and a little more complicated. So keep that in mind.
We changed from 2 pairs of wheels being rotated by one window motor to all four wheel being rotated separately because it would allow the robot to turn more efficiently. When the wheels are connected together and you try to spin the robot, two of the four wheels are dragged on the carpet. This both damaged the carpet and we had to change the wheels tread often in order to have enough grip to climb the bridge.
Unread 13-09-2012, 19:34
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Truth. If you have some members who are stuck on the idea of swerve, tell them to design one. They'll quickly see that it's not as easy as they think.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 13-09-2012, 21:33
FRC #1836 (MilkenKnights)
Though also remind them that the design is less than half the battle. Programming a swerve is the hardest part.
Unread 13-09-2012, 22:04
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
Designing a module is a relatively straight forward challenge with all the CAD out there. A better challenge would be to price one out on a small budget, swerve gets expensive fast.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 13-09-2012, 20:02
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
http://www.youtube.com/watch?v=U7sXWhHfULs
They get a shot of all 6 wheels at 1:45. Its crazy cool.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
