Go to Post I have learned so much from this program and am forever changed by FIRST and its community. You have made me a better person in so many ways. Thank you. - Jessica Boucher [more]
Unread 12-09-2012, 12:17
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Essay about Einstein
I have to do an essay in English. I have chosen the topic of "Einstein should be replayed because of the intentional interference". Though this isn't my exact point of view, I think it would be easier to prove. I need three topic's to be discussed, any specific topics I should touch on?
Thanks for your help
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 13-09-2012, 03:42
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Essay about Einstein
Do you have content requirements—mainly length? With that topic, you may be forced to spend much of the essay explaining things, and have little space to develop an argument. But any way you look at it, you'll have to at least briefly explain what the intentional interference was.
Equity usually makes for a good argument: explain how teams were grievously wronged, and by whom. (If you spread the blame around you can write more words about it. )
You can also assert that the results of the investigation strengthen your argument for that resolution.
Unread 13-09-2012, 08:24
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
I was taught that when making an argument letter, you need solid reasons on why doing something is better than any alternative. In this case, you need 3 reasons why replaying the matches would be better than not.
Tristan's suggestion of equity is a good one. Explain how the team's were extremely wronged. How Einstein is such a huge deal in FRC, and the implications of the wrongdoing to that.
If I were to be reading a letter of why I should replay Einstein (were I in that position... I wish), I would require you to do two additional things.
One, would be precedence. Obviously you won't be able to provide a past experience where Einstein was replayed due to interference, but you may be able to provide a different precedence. For example, matches are generally replayed due to fault of the field. You might be able to argue that the interference occurred through a fault in the field (though that may be a stretch), and thus, citing the FRC Manual, which I believe states matched will be replayed if the field is faulted for an issue that effects the outcome of the match, be able to provide a reason for replaying: Every other match where a field fault has occurred has been replayed, so why not these ones?
Two, I would say you'd need to provide a viable suggestion of circumstance. We can't just ask 12 teams from across the country and Canada to fly to New Hampshire for a few hours so we can determine who really would've one. So if I were to accept your argument, I would think you'd have to make a suggestion as to how we would replay these matches. Where, when, how, things like that.
Another thing I was taught is that you must address any negatives. To simply ignore the reasons to not replay Einstein would be... well... ignorant. You need to discuss the negatives in a "Now one might say ... is a good reason not to replay Einstein, but here's why ... isn't enough of a reason not to replay Einstein compared to the reasons to replay it" format. Discuss the negatives, then explain why they're just not enough to invalidate your argument. If you can do this effectively, you strengthen your argument a lot.
Just some suggestions. Take them as you will.
Good luck with your paper!
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
Unread 14-09-2012, 17:02
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is online now
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
First of all I just want to note that I do not think Einstein should be replayed, however I can see why some people might feel that way.
Anyways, some topics you could go for might include the following:
-Teams were unfairly hurt and had less of a chance to win then others
-this years Einstein matches lacked the skill we are usually used to (not that the teams were bad, but the matches lacked excitement and extremely high scores)
-the winning alliance was not affected by any outside forces (I am not saying they didnt deserve to win)
-lots of robots had communication issues for numerous reasons
-if done without any comm issues, it would make for a very exciting final four
I personally do not agree with all of these opinions and I believe the results should stand, but this is what I think the ideas behind replaying it are.
Hope this helps!
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 15-09-2012, 12:41
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
A couple other points I would have to be really convinced on to replay Einstein are the ethicality of stripping the title of World Champions from Teams 16, 25, and 180, and if replaying the matches would really settle anything, or just cause more drama and controversy.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
