Re: Densest Building Materials
Lead is sometimes used in FRC as ballast (2009). Just don't eat it and you're fine.
Keep in mind that you *can* have a ridiculously heavy robot. Yet after a certain point, it's not worth it -- the FTC motors are very inefficient and the batteries do not charge very quickly. |
I see no reason to use anything other than steel as ballast. 3.5 cubic inches of steel is a pound, and steel is the cheapest relatively dense metal. If you want a really heavy robot, build a ridiculously over-designed steel frame out of solid bars.
I use Andy Baker to build my drive trains. He's pretty dense
Back to FTC ballast -- I recommend U.S. Pennies. You get 100 for only a dollar. They are 0.75 inch in diameter, 0.061 inch thick, and made almost entirely of zinc. A stack of 182 is just over 11 inches long and weighs about one pound. If you have a bigger budget, try U.S. Nickels. They are slightly larger in diameter (0.835 inch) and made mostly of copper, which is denser than zinc. Their larger diameter and density means you only need a 7 inch stack (91 coins, or $4.55 worth) to make one pound of ballast. This is 2.5 times the cost of Penny ballast, at 1.282 times the density. Last edited by Richard Wallace : 19-09-2012 at 20:49. |
Considering these commonly used robot-construction materials:
Andy B. Last edited by Andy Baker : 20-09-2012 at 09:51. |
#8
Which explains why Andy floats. But what also floats? A duck. And wood. So logically, if Andy weighs the same as a duck he must be made of wood, so he must be? ..... A WITCH!!!!!
#9
In cost-effectiveness terms, that's a lot of buck for not much bang. A more practical alternative, and one that many FTC teams would actually choose, is steel ballast. One example is 0.75" diameter low carbon steel bar stock, McMaster 8920K19, $31.12 for a 6 ft. bar. An eight inch length of this bar stock would give you the same ballast mass as the aforementioned eleven inch stack of pennies, at a pro-rated cost (which assumes you have another use for the rest of the bar) of $3.45. About 1.9 times the cost of the Penny ballast, with 11/8 = 1.375 times the density. Steel is looking good compared to U.S. Nickels, and VERY good compared to gold coins. But again, in terms of cost-effectiveness, the U.S. Penny is hard to match. ![]() |
#10
But the roll of pennies got me thinking as to which coin would be best to use from a price/mass ratio. For instance, it would probably be cheaper to use American pennies than Canadian ones because the Canadian dollar is trading higher (this week, at least... a big change from being in the sixty cent range when I started playing this game a decade ago.) I couldn't find out which nation's coinage offered the best mass per dollar ratio, however the closest information that I could find was this site http://www.coinflation.com/ If you go for a pre-1982 US penny, you are actually getting 2.45 cents of copper in every one of them. Not a bad deal at all. Jason |
#11
Didn't they stop minting those earlier this year?
#12
Yeah, but the darn things just won't go away. I think they are breeding like wire coat hangers or something.
Jason |
#13
Getting a Little more serious, one of the densest materials for the buck is something scrap that is laying around. |
#14
#15
Oh, come on... it's the weekend. It's time to be wacky! How about a teaspoonful of Neutron Star?
http://io9.com/5805244/what-would-a-...star-do-to-you Now technically, that might not pass tech, but if you somehow mange to get a teasponfull of neutron star and keep it from destroying the entire planet... well I'm not going to argue whether or not you're allowed to have it on your robot. Jason |
