Go to Post Secure your battery well, or it will fly like a fish. - Nate Laverdure [more]
Unread 13-01-2003, 17:12
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Plastic Retaining Rings
Where do they go on the gearbox??? Thank you for your help.
Unread 13-01-2003, 19:06
illumanat'i's Avatar
illumanat'i illumanat'i is offline
make me care
#0555
Team Role: Student
illumanat'i is an unknown quantity at this point
Send a message via AIM to illumanat'i
see below picture
Trust, Love, and Magic
Unread 13-01-2003, 19:07
make me care
#0555
Team Role: Student
Unread 13-01-2003, 19:19
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
It's a little tough to get at first. Took us about a half hour to get it all aligned properly. Once you have the pieces right, it will be an almost perfect fit. Here's a couple tips:
Fit the motor completelty inside the gearbox before attempting to place anything in the mounts.
If you have the bottom mount sitting flat on a table, the motor can should be oriented so that one of the blue leads is at the top-most part of the motor.
Getting everything to sit properly in the bottom mount is a good idea before you try to install the top retaining pieces. The thickest one goes in front, the thinnest roundest one in the middle, and the squared off one goes over the endbell of the motor in the back (this one isn't quite as good fitting).
Pay close attention to the front part of the gearbox in the drawings and reality as you will see little tabs or ears that will fit right in the mount.
I hope this help.
*When I say front I mean the end with the output shaft.
Unread 13-01-2003, 21:32
Happy Birthday! rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
I think he meant the little circular ones that are very thin and have a weird pattern on the inside that seems to fit perfectly over the shaft they give us. They don't seem to be anywhere in the drawing and we can't find any info on them either.
Just for the record, we have assembled one of these gearboxes, sans aforementioned retaining ring, and it seems to work fine. Any thoughts?
Unread 13-01-2003, 22:21
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
Here are some picture we took at the kick off in Manchester.
http://www.archergeeks1022.org/photo...off/index.html
You can see that First used pieces of the Aluminium tubing to make spacers for the gears. They also used the metal retaining rings to hold the shaft from sliding through the bearings. Let me know if that helps. Also, as you can see in the pictures the motor isn't turned with the leads up they have them off to the sides.
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 14-01-2003, 09:39
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
the retaingin clipy things are soo bad! they kept on flying off the shaft, whenever we tried to turn.
all i can ask is WHY?!
Bad
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 14-01-2003, 10:34
Let's have fun!
#1022 (ArcherGEeks)
Did you install the the right way. They only work one way. If you look at them they should have curve to the teeth. The concave side should be the one you place against the bearing or what ever. This way when you put pressure on it, it will try and dig into the metal and resist being pushed off. I'll see if I can get a picture of this and post it later.
James Grim
www.youthbotin.org
Unread 14-01-2003, 14:12
Adam Y.'s Avatar
Adam Y.
no team (?????)
Thanks you use the plastic rings to hold the shaft in place thanks. Btw be very careful attaching shafts to the aluminum couple I got burs in it by trying to force a shaft into hit.Oppps
Unread 15-01-2003, 09:48
AKA: Mongo
o yea, we tried that, didnt work to hot, o well...
Bad
plastic hubs and drill motors Will Camisa General Forum 4 01-03-2003 00:03
question for anyone who knows their lord of the rings stuff johnscans Chit-Chat 12 11-02-2003 20:07
Lord of the Rings: The Two Towers Jnadke Chit-Chat 55 25-01-2003 16:15
O rings to lock drill in High tareyton Technical Discussion 6 26-01-2002 14:13
Plastic Spur Gears Joe Canavan Technical Discussion 2 25-11-2001 01:45
