Re: 2 Wheel Swerve (2 swerve, 2 omni)
I believe team 100 tried this approach in 2005, although I could be thinking of another team. Instead of a diamond pattern, they had 6 wheels (with the swerve modules in being the middle two of a two by three grid of wheels). I believe they had problems keeping the modules rotating together, which didn't result in a very effective system.
If you're simply looking to eliminate weight, check out some of Bomb Squad's past drivetrains. In addition to an awesome, iterated into oblivion swerve set up, they've tried 3-wheeled swerve. As far as I can remember, it had great performance and substantial weight savings. |
One of the most famous bot's in CD's history had a very similar drive:
http://www.chiefdelphi.com/media/photos/12948 |
See Wildstang and Simbotics (ball casters as opposed to omni-wheels) in 2004. The Simbots were even kind enough to post this whitepaper on their drive:
http://www.chiefdelphi.com/media/papers/1552 |
Are the two omni wheels powered?
That was the only version we tried...it was reasonably successful. We had individual steering using a globe motor. The transmission was integrated into the module.
On paper it was a really great bot. ![]() http://www.chiefdelphi.com/media/photos/14647 |
#8
Yes, they are.
Would there be an optimal driving orientation, assuming the omnis are at opposite corners? i.e, would it drive straight better when the sides are orthogonal or parallel to the direction of movement, or when they are at 45 degree angles? Sorry if I am being unclear. |
