Go to Post And Dave, although I know you have connections, please don't slow the earth's rotation to get more time on the caption contest. ;) - Billfred [more]
Unread 21-09-2012, 14:21
ENIAC's Avatar
ENIAC ENIAC is offline
AKA: Matthew Petersen
FRC #5958 (Blue Wave Robotics)
ENIAC is a jewel in the roughENIAC is a jewel in the roughENIAC is a jewel in the roughENIAC is a jewel in the rough
2 Wheel Swerve (2 swerve, 2 omni)
I had an idea for a novel drivetrain (or at least what I think is novel, someone may already have come up with this), and I wanted to have it checked out:
With a diamond wheel formation, the two corners on the long axis have swerve wheels mounted, and the corners on the short axis have omni wheels mounted, with their plane of rotation parallel to the long axis. The two swerve wheels are chained or belted to allow for simultaneous turning.
Basically, it allows for omnidirectional motion, but uses fewer swerve wheels and so is less mechanically complex*. The downside is that traction falls off towards one direction, but that's a sacrifice you already make with tank. Allows for most of the capabilities of swerve as far as I can tell.
Thoughts?
*call me out on this if I'm wrong
Unread 21-09-2012, 14:34
Re: 2 Wheel Swerve (2 swerve, 2 omni)
It seems like a reasonable approach, but the diamond configuration seems unnecessarily tippy. I think a traditional corners-of-the-rectangle wheel placement should work as well. It shouldn't even matter which two corners the two steerable wheels occupy.
Unread 21-09-2012, 15:29
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I believe team 100 tried this approach in 2005, although I could be thinking of another team. Instead of a diamond pattern, they had 6 wheels (with the swerve modules in being the middle two of a two by three grid of wheels). I believe they had problems keeping the modules rotating together, which didn't result in a very effective system.
If you're simply looking to eliminate weight, check out some of Bomb Squad's past drivetrains. In addition to an awesome, iterated into oblivion swerve set up, they've tried 3-wheeled swerve. As far as I can remember, it had great performance and substantial weight savings.
-Plutarch
Unread 21-09-2012, 20:02
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
One of the most famous bot's in CD's history had a very similar drive:
http://www.chiefdelphi.com/media/photos/12948
Unread 21-09-2012, 22:26
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
See Wildstang and Simbotics (ball casters as opposed to omni-wheels) in 2004. The Simbots were even kind enough to post this whitepaper on their drive:
http://www.chiefdelphi.com/media/papers/1552
Unread 21-09-2012, 23:38
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
We did one back in college...
http://www.chiefdelphi.com/media/photos/14645
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 22-09-2012, 11:19
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Are the two omni wheels powered?
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 22-09-2012, 23:48
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Hello from Michigan Tech. Part of the lower arm of that robot (with the Michigan Tech cut-out) is currently hanging on our cage in the high school where we store the robot. I didn't realize that we had ever done any swerve on the team.
Unread 23-09-2012, 00:04
AKA: Anthony Lapp
That was the only version we tried...it was reasonably successful. We had individual steering using a globe motor. The transmission was integrated into the module.
On paper it was a really great bot.
http://www.chiefdelphi.com/media/photos/14647
Anthony Lapp
RobotOpen
Unread 23-09-2012, 17:02
ENIAC's Avatar
Yes, they are.
I was thinking that as well. I saw the example in Post #6 with the omnis and the swerve modules on separate sides.
Would there be an optimal driving orientation, assuming the omnis are at opposite corners? i.e, would it drive straight better when the sides are orthogonal or parallel to the direction of movement, or when they are at 45 degree angles?
Sorry if I am being unclear.
