Go to Post Chances are it's an electrical or mechanical problem... - mechanicalbrain [more]
Unread 13-01-2003, 17:20
BOBBEY!!!! BOBBEY!!!! is offline
BOBBEY!!!! is an unknown quantity at this point
Complications/restrictions of vertically mounted controll panels
I was wondering if anyone knew of any complications and/or restrictions that are caused by mounting the control panel vertically.
Unread 13-01-2003, 17:41
Jim Smith Jim Smith is offline
#0279 (Tech Fusion)
Jim Smith is an unknown quantity at this point
I've seen controls mounted vertical before. Make sure the wires are tie-wraped to some support, so the vibrations don't cause the 2 and 3 pin connections to come off. Supporting the wires near these somewhat fragile connectors is a good idea no matter which way is up.
Unread 13-01-2003, 18:52
illumanat'i's Avatar
illumanat'i illumanat'i is offline
make me care
#0555
Team Role: Student
illumanat'i is an unknown quantity at this point
Send a message via AIM to illumanat'i
my team had half and half, with the relays and breakers flat and the interface on its side (saved space) - no real problems anyway you do it as long as your sure your robot can handle a hit without turning off (unlike some robots last year . . . . very sad)
Trust, Love, and Magic
Unread 13-01-2003, 19:25
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
What about having it upside-down?
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Unread 13-01-2003, 19:27
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
We have put the electronis in all sorts of positions, even upside down. Other than the occasional wire coming loose, we've never had a problem. After all, electrons don't pay a whole lot of attention to gravity.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 13-01-2003, 19:38
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
We mounted our relays upside down last year - we hot glued the cables in so they wouldn't fall out. As a general rule, if we have and 2-3 pin connectors, we hot glue/electrical tape them! That way we know they're not going anywhere!
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 13-01-2003, 20:29
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
it really doesnt matter what orentation you put the control board. i dont think gravity affects the flow of electricity. the only thing you should consider is that you need to be able to see the led's on the board. it's somewhere in the FIRST rules
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 13-01-2003, 21:47
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
I believe the controller can be mounted as long as the leds on it are visible, so im not sure how you would pull off it being upside down, but vertical is just fine
Unread 13-01-2003, 22:03
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Circuit breakers pointed towards the front or rear of the robot can be bad...if you hit something full speed, you could get them switched. I saw it happen to many teams. We mounted ours vertically so the switch went up or down...we never switched off accidently. If you do mount your breaker facing front, zip-ties work nicely for making sure you don't flip the breaker (We made sure our allies did it...)
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 13-01-2003, 22:05
srjjs's Avatar
AKA: Larry Wang
I wasn't really referring to the flow of electricity, I know the weight of an electron is insignificant.
I meant the ease of access to it.
SVR Imagery Award
RIP Andrew Dang
3/22/2004
Unread 13-01-2003, 22:31
Andy144's Avatar
Andy144 Andy144 is offline
#0006 (Cogsquad)
Andy144 is an unknown quantity at this point
Send a message via AIM to Andy144
More important things to worry about
Last year we mounted our controller upside down, which in and of itself presented no problems, but because of lack of space we ended up attached it to the very outside of our chasis and a piece of plexiglass. NOT a smart thing to do, eventhough we didn't have any drastic consequences because of it, one nasty hit and we would have broken our controller . . . not good!
Unread 13-01-2003, 22:55
EvilInside's Avatar
EvilInside EvilInside is offline
Robots, Cars, Physics!
#0706 (APE)
EvilInside is an unknown quantity at this point
Send a message via AIM to EvilInside
Sup Ya'll from team 706
Well, this is Team 706's first appearance on these boards, and I"d just like to say hi fromt he team. Last year we mounted our circuit board vertically, and had no complications. However, we did put in some guard bars on the outside to prevent ramming action from damaging our controls. Accessability is not a problem if you just take care to NOT block the tether port (like we did). Later.
"All your bins are belong to us" "You can't teach God anything"
Unread 14-01-2003, 08:33
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Theoretically, there can be issues with the ball bearings in the fans on the speed controllers. Mounted at non-horizontal, the ball bearings could fall out. I say theoretically because I've never seen it happen even having mounted electronics on its side. Just something to think about.
Matt
Unread 14-01-2003, 08:37
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Keep in mind that bot (66's) was from the year of 4 v 0 alliances. A few robots did take some solid slams though, whether or not 66 did I don't know. But that's an example of a fully functional bot with a non-horizontal controller
Unread 14-01-2003, 08:49
Addison Addison is offline
Addison is an unknown quantity at this point
That location worked well for us. We never had any problems with the controler even in the few nasty falls from a bridge that would not flip over. The key thing is to have quick and easy access to the controler.
