Go to Post The function of that part is to keep one student occupied playing with it during the entire build season. It doesn't have to be the same student all the time, they can take turns. - MrForbes [more]
Unread 22-09-2012, 18:11
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Motor Calcs with <100% PWM output
How do I adjust a motor speed calculation if my DC motor controller is set at, say, 50% PWM output? Do the stall torque and free speed go down proportionally?
Unread 22-09-2012, 18:23
Re: Motor Calcs with <100% PWM output
As a first approximation, yes.
http://www.chiefdelphi.com/media/papers/2432
Unread 22-09-2012, 20:33
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
Thanks! You've posted all sorts of useful things here - that is much appreciated.
Unread 22-09-2012, 20:41
One other thing to consider is that without additional compensation, 50% pwm on a jaguar will be close to 50% speed. On a victor, it will be significantly faster.
Unread 22-09-2012, 20:50
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
This is a good point. I'm actually looking at this for FTC using Hitechnic DC motor controllers; getting more than 2:1 or 3:1 reduction using Tetrix parts gets bulky, so I am figuring out when it makes sense to do part of the speed reduction with lower PWM output. After your comment, it occurs to me that I don't know how linear those controllers are, so maybe we'll have to do a bit of rough testing.
Unread 22-09-2012, 23:21
FWIW, the Victors get a lot more linear once you put a load on them.
