Go to Post You can't guarantee outcomes -- only effort. If your team did its best, be satisfied. - Rick TYler [more]
Unread 22-09-2012, 18:11
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Motor Calcs with <100% PWM output
How do I adjust a motor speed calculation if my DC motor controller is set at, say, 50% PWM output? Do the stall torque and free speed go down proportionally?
Unread 22-09-2012, 18:23
Re: Motor Calcs with <100% PWM output
As a first approximation, yes.
http://www.chiefdelphi.com/media/papers/2432
Unread 22-09-2012, 20:33
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
Thanks! You've posted all sorts of useful things here - that is much appreciated.
Unread 22-09-2012, 20:41
One other thing to consider is that without additional compensation, 50% pwm on a jaguar will be close to 50% speed. On a victor, it will be significantly faster.
Unread 22-09-2012, 20:50
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
This is a good point. I'm actually looking at this for FTC using Hitechnic DC motor controllers; getting more than 2:1 or 3:1 reduction using Tetrix parts gets bulky, so I am figuring out when it makes sense to do part of the speed reduction with lower PWM output. After your comment, it occurs to me that I don't know how linear those controllers are, so maybe we'll have to do a bit of rough testing.
Unread 22-09-2012, 23:21
FWIW, the Victors get a lot more linear once you put a load on them.
