Go to Post Johnny V-Neun. People just want to be his kind of cool... none of us really know why... - Pamela [more]
Unread 13-01-2003, 11:19
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Custom Mod Controller.
I know it will void the warranty and i know it will probably not be the best idea but i have been debating taking apart an old controller (00 or 01) and replacing the led's with blue and white lenses...maybe...
We have been discussing modding an old controller much like people mod computer cases...
I dont know has anyone ever tried anything like this?
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 13-01-2003, 11:24
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
I've taken an OI apart to fix it after somebody (one of our engineers! ) broke it. I can tell you that removing the LEDs won't be easy. However, if I remember correctly (which I probably don't), all the LEDs are already white and just have red/green lenses built into the OI/RC case. Then again, I took it apart over a year ago and really don't rember too well.
Unread 13-01-2003, 11:32
then maybe i will just switch the lens covering and wablammo custom colored controller!
thanks for the info
Unread 13-01-2003, 11:53
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
The LEDs do appear clear however the LEDs themselves are colored not the OI cover lenses.
Also there's two issues with doing this:
1. Remember that only this years control system (and last years if you have it upgraded) support autonomous mode.
2. Different color LEDs draw different amounts of current. I'm pretty sure that blue and white LEDs draw more current than green, yellow, or red LEDs. You'd have to watch out for this if you swapped out the LEDs as the control system may or may not be able to handle this.
Unread 13-01-2003, 12:00
Originally posted by Dave Flowerday
[b]The LEDs do appear clear however the LEDs themselves are colored not the OI cover lenses.
[b]
That would make a lot of sense. I didn't exactly plug the OI in while holding it in my hands, so all I had to go by was the color of the casing. Thanks for the correction!
Unread 13-01-2003, 15:12
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
Yeah, that and it seems kinda silly to use white led's and just use plastic shades when white led's are about 20 times as expensive (about a buck if you order in bulk, as opposed to 5 cents for red or green). As for the blue led's, I say go for it. Who cares if you'll reduce the life of the oi by 10 years? It'll go out in style ;-)
You can try getting a 2v, 20mA blue one here. I bought these for my case mod, and they're fine. If you could find a place that sells small quantities for under 3 bucks, though, I'd definately like to know.
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 13-01-2003, 15:51
Umm Errr...
modding rules!!!
1139 Alumni
Unread 13-01-2003, 23:48
Gobiner Gobiner is offline
#0753 (High Desert Droids)
Gobiner is an unknown quantity at this point
Send a message via ICQ to Gobiner Send a message via AIM to Gobiner
Remember to post pictures if you mod. I wanna see a 1337 robot controller as much as the next guy.
0N3 1337 PR0G|24MM1N6 N1NJ4
Unread 14-01-2003, 16:37
will do
Unread 17-01-2003, 08:05
Dave is correct here. There are resistors in series with the LEDs that have been calculated for the current drawn by those devices. If you use a higher current demand device, the voltage drop across the resistors may be so great that the new LEDs won't turn on.
C controller Rorschach Kit & Additional Hardware 1 29-10-2003 19:21
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
visibility of robot controller? davidzhang Rules/Strategy 5 26-01-2003 01:11
So what's in YOUR Custom Circuit this year? kmcclary Technical Discussion 7 10-04-2002 12:20
