Go to Post When the world gives you lemons make lemonade serve it at your press conference to expand the program. - Koko Ed [more]
Unread 13-09-2012, 16:54
alicia635769 alicia635769 is offline
FTC #0310
alicia635769 is an unknown quantity at this point
[FTC]: Endgame: What is the defined as "lifting"?
What counts as "lifting" a robot?
Is a "lift" just if no parts of the alliance robot are touching the ground? Or is this a too-broad definition?
Unread 13-09-2012, 17:53
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Re: [FTC]: Endgame: What is the defined as "lifting"?
I'm pretty sure not touching the ground is an accurate description.
Because some people were talking about using a ramp to get a robot to a certain height, which I think was established as acceptable.
Unread 13-09-2012, 20:05
Coin3's Avatar
Coin3 Coin3 is offline
AKA: Griffin Cerva
FRC #4110 (Deep Space Niners)
Coin3 is an unknown quantity at this point
The rules state:
In order to earn the Lifting
Bonus, the lifted Robot must be fully supported by the Alliance partner’s Robot and not by any other game
object (i.e. 100% of the weight of a robot must be supported by the Alliance partner’s Robot).
So yes, it looks like as long as the robot is not touching the ground or any game elements, it counts. The ramps would work, because having the robot on top of the other counts as being fully supported by the bottom robot.
Unread 13-09-2012, 23:49
Derrick Maust's Avatar
Derrick Maust Derrick Maust is offline
FTC, 2008-2012, MATE team |2012|
no team (Techno FORCE)
Derrick Maust is an unknown quantity at this point
It would be really cool if your robot could climb on top of the other robot, just throwing it out there.
FTC team 2818 seasons 08/09-09/10 FTC team 4240 captain seasons 10/11-11/12. WAS "FTC 4240". I am no longer in FTC as a student, I am now a volunteer.
Unread 19-09-2012, 16:51
FTC #0310
Ah, okay. That makes sense. Thanks.
Unread 25-09-2012, 08:04
Greenandead Greenandead is offline
Greenandead is an unknown quantity at this point
Say you were to deploy a ramp to the top of the robot and the robot being lifted only made it half way up the ramp, but is completely on the ramp..would this be considered a legal lift and earn points?
Unread 25-09-2012, 08:21
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
They will score the 'lift' based upon the lowest point of the robot, as defined in the rules. You should experiment to see if what kinds of robots will stay in place after power is cut while on a ramp.
GitHub
Unread 26-09-2012, 14:34
MarcSol's Avatar
MarcSol MarcSol is offline
FTC Mentor, FRC Ref, FLL Ref
FTC #5037 (got robot?)
MarcSol is an unknown quantity at this point
Send a message via AIM to MarcSol
I wondered about this also. Someone asked the official USFIRST.org FTC Game Q & A about the following 3 scenarios:
  1. Robot A deploys a ramp and Robot B drives up the ramp.
  2. Robot A deploys a platform onto which Robot B drives. Robot A then lifts the platform, thus lifting Robot B.
  3. Robot A deploys a jack-type mechanism. Robot B drives over it. Robot A operates the jack to lift Robot B.
And were told that all 3 would be legal.
On a related note, someone asked if the floor was a field element ("Lifting Robots may not use any field elements (i.e. the Rack, Ring Dispensers, etc.) to aid with the lifting of a Robot.") and were told:
It depends on what is meant by "the floor." The Lifting Robot is allowed to be in contact with the Playing Field's foam tile floor. The Center Floor Goal is a Field Element and therefore, Robots may NOT be in contact with the Center Floor Goal and receive Lifting Bonus points.
So trying to take advantage of the added height of the Center Floor Goal would invalidate the lift.
