Go to Post Just a word of advise dont come running up to someone and say OMG OMG its just remember to introduce yourself first. - Mike Schroeder [more]
Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Unread 25-09-2012, 23:32
Gdeaver Gdeaver is offline
FRC #1640
Re: Victor 888: Upgrade to the Victor 884
The window motor thermal shut down with the locking pins removed and a jag was only seen when used in a positioning application controlled by a PID. We used the window motors for our swerve steering - 4 wheel independent continuous rotation. With the jag we had intermittent thermal shut down with the jag. We switched to victors and had no more problems even with extended run times during practices in a hot building in the summer. We have used the window motors in other non - positional applications and not had problems with the jags. Of course if the window motor is over loaded it will shut down with any controller. It will live to run again. For what ever the reason jags and window motor in positional applications is probably not a good idea. We have used the banesbot motor and transmission for 2011 and 2012 avoiding this problem.
Did you find that the output of the Talon was linear or did you have correct it in software?
There have been many versions of the jag. I'm almost certain one version used lock anti phase. If I remember right they have gone from a high side switcher to locked anti phase to the current low side switching.
The manual states the pulse as .9 to 2 ms is this a typo? Should it be 1 to 2 ms and will use the victor motor routines for programming?
Our team has a problem of marathon diver practice . A battery change is not a cool down period. If we end up using Talons they will have fans.
Another motor controller option. I like options. Thanks for the attempt to support First. Have they given any hint of the Talons legality for 2013?
Unread 26-09-2012, 10:01
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
[quote=Gdeaver;1187367]The window motor thermal shut down with the locking pins removed and a jag was only seen when used in a positioning application controlled by a PID. We used the window motors for our swerve steering - 4 wheel independent continuous rotation. With the jag we had intermittent thermal shut down with the jag. We switched to victors and had no more problems even with extended run times during practices in a hot building in the summer. We have used the window motors in other non - positional applications and not had problems with the jags. Of course if the window motor is over loaded it will shut down with any controller. It will live to run again. For what ever the reason jags and window motor in positional applications is probably not a good idea. We have used the banesbot motor and transmission for 2011 and 2012 avoiding this problem.
The output duty cycle is scaled linearly to the input, no additional math was needed to obtain a linear output.
There have been many versions of the jag. I'm almost certain one version used lock anti phase. If I remember right they have gone from a high side switcher to locked anti phase to the current low side switching. ?
The FRC version of the Jaguar has always been a high side switching synchronous sign-magnitude switcher. If there are any plots to prove otherwise I would like to see them.
The manual states the pulse as .9 to 2 ms is this a typo? Should it be 1 to 2 ms and will use the victor motor routines for programming?.?
This is not a typo. The Victor routines will work with the Talon. It is always a good idea to calibrate any motor controller however.
Another motor controller option. I like options.?
This is probably a good idea if you are performing back to back practices at your build facility. However in a competition it may not be necessary. If you notice the Talons thermal plots are on a 10 minute interval with a 30% duty cycle (3 minutes at specified current, 7 minutes off). This is on purpose as most matches have ~10 minute turn around. (start to start) Now keep in mind the matches only last 2 minutes and 15 seconds. So even if your robot slams into a wall at full speed at the beginning of auton and continues to run at full speed for the remainder of the match, you will not damage the Talon. With that said it can only help with performance to use the fan. Our rule of thumb is use the fan for any Talon on a 40 amp breaker. Of course this is only relevant if the Talon is deemed legal.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 26-09-2012, 11:20
Black Jag. See Figure 4-4 on Page 19:
http://www.ti.com/lit/ug/spmu130c/spmu130c.pdf
ID:	13036  Click image for larger version
Unread 26-09-2012, 15:46
President, VEX Robotics, Inc.
Originally Posted by Jim Wilks View Post
From the posted information:
Any Debris that does enter the housing won't get past the conformal coating that protects the surface mount components.
A conformal coating on the the PCB! Now that's a huge step in the right direction for FRC motor controllers where metal shavings always seem to find their way into motor controllers.
As a point of clarification, all of the Victors since their creation (1999) have had conformal coating. The 884 has it and so does the 888 (and so did the 883, 885, etc.).
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 26-09-2012, 16:06
AdamHeard's Avatar
Lead Mentor
This is just a guess, but are the 888 and Talon related at all?
Unread 26-09-2012, 16:14
No. No relation other than the engineers that work on each are brothers.
However, IFI had no input on the Talon and CTRE had no input on the Victor 888.
Unread 26-09-2012, 18:15
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Is there any particular benefit to using a Talon over a Victor or Jaguar? Am I correct in thinking it goes something like this:
Jaguar - Cheapest, bulkiest, most flexible functionality
Victor - Most expensive, smallest, most reliable
Talon - Somewhere in-between?
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 26-09-2012, 18:40
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
I believe the Talon is smaller then the victor, especially when it is run fan-less. Also the Talon is rated to handle more amps then the victor so victor vs talon reliability is up for question, no one has really tested the Talons like the victors.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 26-09-2012, 21:08
Again, for a point of clarity the Victor is $89 so it is not the most expensive. Actually, it is the least expensive compared to the Talon on AM and the Jaguar on Mouser.
Unread 26-09-2012, 22:02
F22Rapture's Avatar
AKA: Daniel A
It looks like Vex's site is a bit misleading then.
http://www.vexrobotics.com/victor-speed-controller.html
It says "starting at $199.95" but then further down the page it lists "$89.99" as the actual starting price. Possibly because the $90 variant is out of stock. When I checked the first time I only noticed the "starting at" price.
Thanks for the correction.
- Wernher von Braun
Unread 27-09-2012, 03:14
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Originally Posted by jwfoss View Post
If I remember correctly, there was a number of teams running the Talon motor controller at IRI and it seemed well up to the challenge. Perhaps they can speak up here.
I spent some time at their booth talking to them about it. Besides the linear output another nice feature was a tighter fit on the pwm cable (I saw them lift the controller while it was powered up by the pwn cable)
The heat sink looked nice and seemed to go further with protecting the internals of the unit, and it still retained mounting holes for a standard fan.
This is interesting.
I never saw Mike talk about it at all when I saw the Talon, but this alone would make me choose this over the current 884s, even with the price difference. What about the 888's?
We've had instances with failed Jags before and never went back to them, other than a few robot functions for "smoother" output. The Victors size and reliabilty are so much better, other than the occasional poor connection with the PWM input.
Unread 27-09-2012, 09:09
FRC #1640
It's my understanding that the only difference between a 884 and a 888 is that the out put has been made linear. If you have gown to love the Victors the 888 is the same only one little issue has been fixed. Interesting that this year we lost 2 884's however these were very old units that had been abused on many other robots and a ball lift jam finally killed them. The victors have proven reliable.
Unread 28-09-2012, 23:03
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
As another alternative, I would like to see these used. They are definitely a cheaper alternative:
http://www.canakit.com/50a-dc-pwm-mo...ontroller.html
Especially if you buy in bulk here (10+):
https://www.sparkfun.com/products/9668?
Also, to whom mentioned a lower amp version, they sell a 30A that is just slightly more that 1/2 the price:
http://www.canakit.com/30a-motor-spe...oller-pwm.html
Unread 28-09-2012, 23:16
Since those don't accept a servo style PWM input, what would you use them for in a FIRST robot?
Those only control speed, not direction. They also have an inappropriately high minimum voltage, and include knobs. I'll stick with the existing options.
