Go to Post Robotics for me though really is hard to beat. Though tiring and exhausting, the memories you build are priceless. - ShadowKnight [more]
Unread 26-09-2012, 16:33
DeadlyJohny DeadlyJohny is offline
FRC #3417
DeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to beholdDeadlyJohny is a splendid one to behold
Is it possible to control a Jaguar with a potentiometer?
We need a super quick and easy way to give a jaguar power from the batter, output to a motor, and be able to give an input to it. This is simple for testing purposes but I'd like the input mechanism to be small and portable, any ideas?
Unread 26-09-2012, 16:42
Re: Is it possible to control a Jaguar with a potentiometer?
What you're looking for is often called a servo tester. You can find many schematics online, or buy one from many different hobby sites. Here is one made by a mentor from team 987: http://robotlogic.com/product_servotester.html
Unread 26-09-2012, 16:43
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
It would require a PWM signal. There are a few cheap PWM signal generators out there that i've seen others talk about on CD here, but i've never used one... The short story is no, you cannot control it with just a potentiometer, it's a little more complicated
2016: Lake Superior WFFA
Unread 26-09-2012, 16:44
anthonyttu anthonyttu is offline
Texas Instruments Engineer
AKA: Master Chief
FRC #5417 (Eagle Robotics)
anthonyttu has a spectacular aura aboutanthonyttu has a spectacular aura about
An RC controller would be the easiest way to do what it sounds like your trying to do. You would only need the RC transmitter, the receiver and a battery/power supply. You can plug the receiver directly into a JAG with PWM cable.
Unread 26-09-2012, 17:46
Do you consider a laptop or notebook computer to be small and portable?
http://www.chiefdelphi.com/media/papers/2702
Unread 26-09-2012, 18:41
dave1027 dave1027 is offline
FRC #1027
dave1027 will become famous soon enough
I believe the answer to your question is yes...kinda.
You can use a potentiometer to control a jaguar but first you will have to run to radioshack(the shack) and pick up a few things.
You should be able to generate the appropriate signal using a basic 555 timer circuit. I am on my phone righht jow so i do not have the specifics but there are enough web pages a quick google for 555 timer circuit will provide the circuit. The 555 timer circuit uses two resistors to determine the frequency and pulse width of the ouput signal. You should be able to use a poteniometer for the pulse width resistor to create a very simple circuit on a breadboard thst will control a jaguar output via a potentioneter without using any type of digital control.
Sorry this explanation may be better suited to the slightly more advanced reader but a little research online should be enough to enlighten even a beginner.
Unread 26-09-2012, 21:32
DonRotolo's Avatar
Back to humble
FRC #0832
I made a post on chief Delphi a few years ago showing a circuit that does exactly that. You might want to search for it.
Unread 26-09-2012, 21:50
I had the link handy so here it is:
http://www.chiefdelphi.com/forums/sh...3&postcount=34
Unread 27-09-2012, 03:16
dtengineering's Avatar
AKA: Jason Brett
I was wondering if it might not be possible to set the Jag to Analog Position Control Mode using an RS-232 or CAN connection, telling it to head for the 1.5V position. Then set only a proportional response, no I or D.
As you swing the pot to one side the motor should move in one direction, with increasing power relative to the "error" in the Pot. Swing it the other way and the motor should turn in the other direction.
Not that there is anything wrong with the other ways, but is there a reason this wouldn't work? I haven't played with the Jags for years, so I'm just working from the manual here...
Jason
P.S. Not that I don't use 555 timer circuits, but I'd probably be tempted to use a PIC or Arduino to generate the serial code for the Jag, but they could also generate PWM code quite easily. A 16f88 or similar would be a one chip solution... easily programmable in Great Cow Graphical Basic, using a PICKIT2 or PICKIT3 programmer and a breadboard.
Unread 27-09-2012, 03:22
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Here is the link to our white paper with pics.
http://www.chiefdelphi.com/media/papers/2699
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 27-09-2012, 10:16
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Here is a link to what we use:
http://gadgetgangster.com/find-a-pro...projectnum=206
You need to lower the value of the output current limiting resistor then it works great.
I suggest you add a current probe to your test rig so you can measure current while you are testing your systems. A 10 gauge wire 12" long works perfect. Use that wire as a shut, it will measure 1 millivolt for 1 amp. There are several threads here that discuss that scheme. Do a search for stangsense.
Here is a photo of our rig that can control two motors. In this photo the motor is running and drawing 3 amps. By having this information you can know that your motor is running within the correct range and that the magic smoke will remain.
-Hugh
Unread 27-09-2012, 10:35
Gdeaver Gdeaver is offline
FRC #1640
I have found that a Pololu RC controller to be handy for some robot testing.
http://www.pololu.com/catalog/product/1352
You could do the same thing with an arduino, but the control application that you would run on the laptop makes it easy to use. Can also read analog 0 to 5 volts so it can double as a sensor checker.
Unread 27-09-2012, 10:38
AKA: Master Chief
Using the CAN/RS-232 method only works if always want to have a laptop or MSP430 or something else to always connected to the CAN buss. If you are going that far there is not much to gain.
Unread 27-09-2012, 10:40
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I'm really impressed with how much effort we'll go to, to avoid buying a $25 servo tester.
Unread 27-09-2012, 22:18
DonRotolo's Avatar
Back to humble
FRC #0832
A 556 also is a one chip solution. For me, a non-programmed solution is almost always superior to one needing programming. (Not that I dislike programming, it just seems like overkill)
Just like Ham radio operators, robot people are cheapskates. Thus the attraction of building a solution for $4 to avoid spending $25.
