| Thread Tools |
Rating:
Display Modes |
#16
Re: Victor 888: Upgrade to the Victor 884
The window motor thermal shut down with the locking pins removed and a jag was only seen when used in a positioning application controlled by a PID. We used the window motors for our swerve steering - 4 wheel independent continuous rotation. With the jag we had intermittent thermal shut down with the jag. We switched to victors and had no more problems even with extended run times during practices in a hot building in the summer. We have used the window motors in other non - positional applications and not had problems with the jags. Of course if the window motor is over loaded it will shut down with any controller. It will live to run again. For what ever the reason jags and window motor in positional applications is probably not a good idea. We have used the banesbot motor and transmission for 2011 and 2012 avoiding this problem.
Did you find that the output of the Talon was linear or did you have correct it in software? There have been many versions of the jag. I'm almost certain one version used lock anti phase. If I remember right they have gone from a high side switcher to locked anti phase to the current low side switching. The manual states the pulse as .9 to 2 ms is this a typo? Should it be 1 to 2 ms and will use the victor motor routines for programming? Our team has a problem of marathon diver practice . A battery change is not a cool down period. If we end up using Talons they will have fans. Another motor controller option. I like options. Thanks for the attempt to support First. Have they given any hint of the Talons legality for 2013? |
#17
[quote=Gdeaver;1187367]The window motor thermal shut down with the locking pins removed and a jag was only seen when used in a positioning application controlled by a PID. We used the window motors for our swerve steering - 4 wheel independent continuous rotation. With the jag we had intermittent thermal shut down with the jag. We switched to victors and had no more problems even with extended run times during practices in a hot building in the summer. We have used the window motors in other non - positional applications and not had problems with the jags. Of course if the window motor is over loaded it will shut down with any controller. It will live to run again. For what ever the reason jags and window motor in positional applications is probably not a good idea. We have used the banesbot motor and transmission for 2011 and 2012 avoiding this problem.
This is probably a good idea if you are performing back to back practices at your build facility. However in a competition it may not be necessary. If you notice the Talons thermal plots are on a 10 minute interval with a 30% duty cycle (3 minutes at specified current, 7 minutes off). This is on purpose as most matches have ~10 minute turn around. (start to start) Now keep in mind the matches only last 2 minutes and 15 seconds. So even if your robot slams into a wall at full speed at the beginning of auton and continues to run at full speed for the remainder of the match, you will not damage the Talon. With that said it can only help with performance to use the fan. Our rule of thumb is use the fan for any Talon on a 40 amp breaker. Of course this is only relevant if the Talon is deemed legal. |
#18
#19
This is just a guess, but are the 888 and Talon related at all?
#21
However, IFI had no input on the Talon and CTRE had no input on the Victor 888. |
#22
Is there any particular benefit to using a Talon over a Victor or Jaguar? Am I correct in thinking it goes something like this:
Jaguar - Cheapest, bulkiest, most flexible functionality Victor - Most expensive, smallest, most reliable Talon - Somewhere in-between? |
#23
I believe the Talon is smaller then the victor, especially when it is run fan-less. Also the Talon is rated to handle more amps then the victor so victor vs talon reliability is up for question, no one has really tested the Talons like the victors.
#24
http://www.vexrobotics.com/victor-speed-controller.html It says "starting at $199.95" but then further down the page it lists "$89.99" as the actual starting price. Possibly because the $90 variant is out of stock. When I checked the first time I only noticed the "starting at" price. Thanks for the correction. Last edited by F22Rapture : 26-09-2012 at 22:18. |
#26
I never saw Mike talk about it at all when I saw the Talon, but this alone would make me choose this over the current 884s, even with the price difference. What about the 888's? We've had instances with failed Jags before and never went back to them, other than a few robot functions for "smoother" output. The Victors size and reliabilty are so much better, other than the occasional poor connection with the PWM input. Last edited by waialua359 : 27-09-2012 at 03:18. |
#27
It's my understanding that the only difference between a 884 and a 888 is that the out put has been made linear. If you have gown to love the Victors the 888 is the same only one little issue has been fixed. Interesting that this year we lost 2 884's however these were very old units that had been abused on many other robots and a ball lift jam finally killed them. The victors have proven reliable.
#28
As another alternative, I would like to see these used. They are definitely a cheaper alternative:
http://www.canakit.com/50a-dc-pwm-mo...ontroller.html Especially if you buy in bulk here (10+): https://www.sparkfun.com/products/9668? Also, to whom mentioned a lower amp version, they sell a 30A that is just slightly more that 1/2 the price: http://www.canakit.com/30a-motor-spe...oller-pwm.html |
#29
