Go to Post How else can I get my polar bear sized tub of Lard? - niklas674 [more]
  #31   Spotlight this post!
Unread 27-09-2012, 11:54
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: New Talon Speed Controller
Calibration of motor controllers is a pretty standard practice in RC (especially in the quad rotor world). If the controllers aren't calibrated, the motors will not be in sync (i.e. receive the same power input) -- which could be an issue for motors that are mechanically linked. In quadrotors, the motors are linked via software PID for stability purposes, meaning uncalibrated motor controllers will cause a quadrotor to crash almost immediately.
GitHub
  #32   Spotlight this post!
Unread 27-09-2012, 12:10
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Originally Posted by Mike Copioli View Post
If the Talon is deemed legal a Talon Class would most likely exist.
Any hint from FIRST as to when we might know if the Talon is legal? Before Jan 5th?
  #33   Spotlight this post!
Unread 27-09-2012, 12:39
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Mike,
We switched to use CAN bus last year and was starting to enjoy using it. Plus we have invested in a couple of 2CANs. Any idea if Talon will eventually support CAN?
  #34   Spotlight this post!
Unread 27-09-2012, 12:44
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I suggest the first hint will probably come to the Beta Test teams, but there probably won't be any guarantee until kickoff!
2016: Lake Superior WFFA
  #35   Spotlight this post!
Unread 27-09-2012, 13:59
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Originally Posted by mikets View Post
Mike,
The answer is yes. And thank you.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
  #36   Spotlight this post!
Unread 17-10-2012, 19:34
dsirovica's Avatar
dsirovica dsirovica is offline
Programming and Electrical Mentor
AKA: Dean Sirovica
FRC #1458 (Red Ties)
dsirovica is on a distinguished road
Greetings, a new season has begun! and we seem to have a new speed controller that looks like a Vic!
A quick look at the Jag schematic says that when the robot is pushed, the generated current will try to flow in such a way to charge the battery. But if the battery is not connected the voltage to the PDB will keep rizing... Is there something in the PDB that will shunt this current - or something will blow!
Dean
Originally Posted by Camren View Post
Ok to clarify my above post.
Are team has found that any sort of free wheel action on the robot (ie pushing it) Causes the motors to become a generator that sends current back into the motor controller. Well with the Jaguars they didn't have anything to stop it so we fried a lot of them. The new Talon controller has
  #37   Spotlight this post!
Unread 18-10-2012, 07:42
Camren,
The type of locked antiphase PWM modulation that is used in the Talon is simply the method that used to turn on the FETs that provide motor currents. The FETs in the Talon, Victor and Jaguar all have diodes that provide a path back to the power supply while the motors are coasting or being pushed. This diode is a result of manufacture as I understand.
Rickie and Jon, not to mislead, the conformal coatings on the Victors protect the circuit board components, but the leads of the FETs are still sometimes exposed. Metal swarf still can kill a Victor but they are far more immune to this than the current TI/Luminary production Jaguars. I am going to guess (highly recommend) that the IFI production runs will contain the same conformal coatings as current Victor products. The really difficult component in the Jag to coat is the current sense resistor since this can dissipate large amounts of power/heat. However, if metal falls across it, there isn't likely to be any catastrophic failure since the value is so small.
  #38   Spotlight this post!
Unread 18-10-2012, 07:56
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Camren,
Al,
Yes, the Jaguar will feature the same conformal coating as the Victor.
Best,
Ricky
Ricky Quinones
Director of Sales - VEX Robotics
  #39   Spotlight this post!
Unread 18-10-2012, 12:13
dsirovica's Avatar
AKA: Dean Sirovica
Sorry I've been out of the loop on this all summer:
What was the outcome of FIRST's RFP for Jaguar replacement?
Thanks,
Dean
  #40   Spotlight this post!
Unread 18-10-2012, 12:17
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Thanks,
Dean
http://www.usfirst.org/roboticsprogr.../blog-10-03-12
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
  #41   Spotlight this post!
yee haw!
Thanks,
Dean
Dean,
Going forward, IFI will be manufacturing, selling, supporting, and donating Jaguars to the 2013 Kits of Parts.
More details are here: http://www.usfirst.org/roboticsprogr.../blog-10-03-12
Ricky
Ricky Quinones
  #42   Spotlight this post!
Unread 18-10-2012, 12:56
dsirovica's Avatar
AKA: Dean Sirovica
Thanks and excellent news!
I noticed he following:
"Second, the firmware will be modified to remove the current limit protection "
That is great too as that was probably the most significant issue with the Jag (there are others elaborated on on the blogs). However, I hope the current limit is only increased rather than dissabled completely (as in by shorting R23).
Thanks,
Dean
Originally Posted by Ricky Q. View Post
Dean,
Ricky
  #43   Spotlight this post!
Unread 18-10-2012, 16:22
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
This was a typo in the User Manual. The actual refresh rate is 333Hz or (3 ms). The input capture is driven by an interrupt so as long as there is some space between the edges of the input pulse, the output will update correctly.
If your pulse spacing is 3 ms or greater you should have no problem.
All of our testing over the last 2 weeks has been at a refresh rate of 242Hz, as I was too lazy to reconfigure the PIC we're using for pulse generation.
I hope the Talon gets FRC approval. So far, this thing is bulletproof.
  #44   Spotlight this post!
Unread 18-10-2012, 18:16
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Originally Posted by Nemo View Post
I'm super interested to hear what the electrical nerds have to say about this product. Is there any reason to stay with the Victor over the Talon (cost aside)?
Here's hoping we get some of these in the kit of parts.
So far, we've seen a whole lot of reasons to choose the Talon over the older Victors. The biggest one for us is that the talon is showing linearity as good as the Jag, better control around the zero point (smaller dead band), and a victor-sized footprint.
For an idea of just how bad the linearity is on a the Victor, look here:
http://www.fightingpi.org/Resources/...12_Day_3.shtml
Many teams have fixed that in software - so it can be done, but it's an extra step that is better handled in hardare.
Of course, there's a new Victor coming out as well. It's not exactly fair to compare an old product to the new Talon. Apples to apples will be the new Victor vs. the Talon.
  #45   Spotlight this post!
Unread 19-10-2012, 10:07
Racer26 Racer26 is offline
Wow. That non-linearity is pretty ugly.
