Go to Post High heels on a Segway takes quite a bit of adjustment - as I learned the hard way. - Jessica Boucher [more]
Unread 09-25-2012, 11:30 PM
NetworkTables on PC
I'm trying to prototype some code using NetworkTables on my PC, without needing a cRIO. However, when I run it, I get an exception pointing to the following line in edu.wpi.first.wpilibj.networktables.ConnectionMana ger.java
server = (ServerSocketConnection) Connector.open("socket://:" + PORT);
I'm assuming it's because the NetworkTable code was targeted for the robot and JavaME. Is there some way to run this code on my computer, like a JavaME SDK, or emulator, or something?
Unread 09-26-2012, 11:47 PM
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: NetworkTables on PC
You can compile the Squawk VM to run on desktop platforms. Instructions are given at http://java.net/projects/squawk/pages/BuildingSquawk with the small caveat that the SVN repository has moved to https://svn.java.net/svn/squawk~svn/trunk/. Note that this isn't a complete answer because a lot of the WPILib/FRC Framework functionality require native library calls, but it should get you very close if all you need is the NetworkTables.
Alternately, there's an effort going on at http://sourceforge.net/projects/frcsimulator/ with some alpha code to develop a "cRIO simulator" for the Java platform.
FRC 766, 2015-, Mentor
Unread 09-27-2012, 11:56 AM
I found an easier way. In the smartdashboard SVN on firstforge, there is a NetworkTable Client, Server, and Robot folder. The Server did what I needed and ran on my PC.
I could only find these in the 2012 tag. They seem to have been deleted in trunk.
Unread 09-27-2012, 01:31 PM
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
My understanding is that this is being reorganized to better share the implementation. In the past there were basically 3 separate code-bases that all needed to be kept in sync.
