Go to Post It's not a problem, it's a feature! - smokescreen [more]
Unread 27-09-2012, 12:37
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
pic: Team 3647: Rebound Rumble take 2
Unread 27-09-2012, 12:39
ttldomination's Avatar
Sunny
Re: pic: Team 3647: Rebound Rumble take 2
Looking nice, just a couple of questions for you.
(1) Are you delivering the balls straight into the shooter via your belts?
(2) I can't tell if its the perspective, but it looks like your chassis might be bowing in the middle. Is that just me?
(3) Did you guys machine the tubing + things in house?
(4) What tips/advice would you recommend using the gussets? Do they provide enough rigidity?
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 27-09-2012, 12:55
Chris is me's Avatar
AKA: Pinecone
I like the rebuild!
It looks kinda like your wheels are sticking out of the frame. Is this going to be a problem once you add bumpers?
How consistent is the shooter?
I like the 973-style hole pattern. I wish we did something like that, but we don't exclusively use 1 wide tubing so it's less elegant.
Unread 27-09-2012, 14:20
Mk.32's Avatar
AKA: Mark
More Photos at: https://www.facebook.com/media/set/?...11235&type= 1
1. We are delivering the balls straight into the shooter, so far it is working well for us; the hand off from belt to shooter is pretty smooth.
2. Hm I am pretty sure that is just the way the photo is taken, the frame is pretty rigid.
3. Yes the entire robot was machined by students; we have an local machine shop sponsor us and I was allowed to use the CNC mill to run all the parts.
4. The gussets on the frame are 1/8 thick and the tower ones are 3/32. So far we have no issues and from what it looks like from other teams as well 1/8 thick on the frame is more then plenty.
The bumpers are a work in progress at the moment, the mounts may not be 2012 Legal but it's off season
The shooter so far is very consistent, we have an encoder with a PID control loop on it. In the following weeks we plan to test the crap out of this bot.
The hole pattern was so we could add/change elements as we see fit, it's consistent pattern though out.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 27-09-2012, 14:24
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Nice work but I look at all that hardware and think how much lighter you could be with rivets holding it together instead bolts.
Unread 27-09-2012, 14:29
adam the great's Avatar
adam the great adam the great is offline
Strategy Mentor
AKA: Adam Brewster
FRC #2168 (Aluminum Falcons)
adam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud of
Looks great guys. Interested in seeing which manipulator for the bridge you choose to go with.
~Adam Brewster~
2168 (Drive Coach/Strategist)
Past Teams: 1930, 2228, 229, 4124, 5240#NeverForget4124
Unread 27-09-2012, 14:37
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Ditto, most of your hardware seems like your never going to take it apart. Even if you were, rivets are pretty easy to drill out.
You can use High strength or Normal Rivets with no issues. 3/16" Rivets and #10 bolts are interchangeable.
-RC
R.C.
MadTown Robotics Team 1323
Unread 27-09-2012, 15:28
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
I would like to congratulate your team on doing a great off-season project.
Unread 27-09-2012, 18:40
Mk.32's Avatar
AKA: Mark
Thanks everyone for the nice comments, we are quite proud of this little guy and hope it performs well at off season.
We considered using rivets however we had an bad experience with rivets before and decided that bolts are safer. Are pop rivets really suitable to replace 1/4 bolts?
Unread 27-09-2012, 18:43
AKA: Pinecone
Depending on how they are loaded (i.e. mainly in shear), rivets can absolutely replace bolts. Based on the pattern of gussets on the robot, it almost looks like the robot was designed to be primarily riveted.
Unread 27-09-2012, 18:47
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Cause they really needed to save weight eh? If anything they should add some steal plates to make it heavier.
Looks great, it just proves to al of us how small and light we could have made our bots.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 27-09-2012, 18:48
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Even 1/4in rivets can be overkill but since rivets are so light it doesn't really matter. My biggest peeve with the kitbot is the 32 nuts and bolts we have to use its like dead weight!
Is your shooter designed to hit the top basket or is it a mid/low?
Overall your redesign looks great! Best of luck to you guys!
1058 PVC Pirates 2016 - xxxx
Unread 27-09-2012, 18:52
AdamHeard's Avatar
Lead Mentor
Talk to us at the fall classic and I'll show you how we utilized rivets.
We actually standardize on 3/16" rivets, and they are plenty strong if used right.
Unread 27-09-2012, 19:04
This year we used 3/16 Rivets. IMO the best decision we made was going to Rivets, so much better then bolting everything together.
Do you think we would have a problem switching over to 1/8" Rivets? I was considering doing that this year, but if 3/16" would be a better choice I will stick with those.
2013-Present
2010-2013
Unread 27-09-2012, 19:23
IndySam's Avatar
We have used 3/16 rivets and gussets for years without a single failure. For higher stress areas we also add epoxy.
