[FTC]: Encoder cables
Does anyone know what is the easiest way to extend the encoder cables (or replace them by a longer ones) - short of cutting in the middle and soldering in 4 new wires?
USdigital which produces the encoders used by TETRIX motors sells these replacement cables which can be oredered in any length: http://usdigital.com/products/cables.../CA-MIC4-SH-NC but the other end is unterminated, so we need to also find the 4-pin connector that plugs into the motor controller. Anyone has doen this before? |
Re: [FTC]: Encoder cables
Yep, done that. The parts and tool to finish off the ends of those are all available from digikey. Just use care. The pins are small and easy to under/over crimp. Also use caution inserting pins into housings.
The housing is Digikey part number 609-2396. The pins are part number 609-3620-1. The inexpensive tool to crimp them is: Universal Crimp Tool WM9999-ND 33.75/1 63811-100 Best Regards, |
We have some broken cables too but on a similar note we have a Tetrix motors with a broken gear box and encoder. I've been puzzling about how to get the encoder off without damaging it. I called US Digital tech support and they directed me to this video on how to properly remove the encoder assembly with out damaging the parts.
https://www.youtube.com/watch?featur...&v=6Hx7TvpAJXA |
Here are some additional parts...
Here are the Digikey parts that I believe will work for the encoder cables: Micro Molex connector http://search.digikey.com/scripts/Dk...2-ND&x=18&y=18 Micro Connector Terminal Female pins http://www.digikey.com/product-detai...2023-ND/313482 There is a Micro Molex Crimper, don't have the part number ???? 4 Pin Connector Housing http://search.digikey.com/scripts/Dk...6-ND&x=15&y=15 Encoder Cable http://www.usdigital.com/products/ca...ca-mic4-w4-nc/ You can order these with various lengths. We ordered the 2ft version. We ordered the 4 pin crimper from http://www.hansenhobbies.com/products/connectors/ The Deluxe crimper can be used for both female connectors for the Micro Molex Connector, and the 4 Pin Connector Housing, results vary. You can order servo wire pins for the 4 Pin Connector Housing, and various size connector housing (we use them a lot for FRC). We ordered a Deluxe RC Connector Kit, it has saved us many times. Eric Grajales Exploding Bacon Team 1902 Last edited by g_less1902 : 27-09-2012 at 17:35. |
Our good friends at AndyMark (www.andymark.com) also sell PWM Cables.
Jamie, Eric, Mannie, thanks! We might try this.
BTW: Cougar Robotics - aren't you the team that won FLL US open back in 2009? Dug out an old photo... https://lh3.googleusercontent.com/-t...090509-046.jpg |
#7
Does anyone have an alternate source / method for making these extended encoder cables? The supplier for the 4-prong cable ends described in this post says they will not have any more available until the end of February (tooooo late)
thanks - FTC Team 6389 Last edited by FTC6389 : 14-01-2013 at 14:07. |
