Go to Post While the Banners initiate the outreach, eventually, the outreach becomes the Banner. - MysterE [more]
Unread 20-09-2012, 18:11
TeraViks's Avatar
TeraViks TeraViks is offline
AKA: Brian Induni
FRC #3145 (TeraViks)
TeraViks is a jewel in the roughTeraViks is a jewel in the roughTeraViks is a jewel in the roughTeraViks is a jewel in the rough
Systems schema visual
Hello all,
We are in our 4th year, and I'm determined to put together some good programming training material for the programming students on the team, so I have this question: Does anyone out there have a good visual representation of the FRC systems? I'm trying to explain at a high level how the systems work together (LabView, WindRiver, C++, cRio, etc) and at the same time put together a clear document on how to install (and update) the needed software components.
Thanks!
Brian
FIRST team 3145 (notice I'm doing Dean's homework!)
The TeraViks
Coeur d'Alene, Idaho
Unread 20-09-2012, 18:45
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: Systems schema visual
Like this?
Source: http://www.instructables.com/id/Cont...sics/?ALLSTEPS
Depending on which language you're using, the WPI Library Users Guide and WPIlib Cookbook have some nice diagrams on how the electronics interface with each other.
https://dl.dropbox.com/u/27736599/wpilib%201.png
https://dl.dropbox.com/u/27736599/wpilib%202.png
https://dl.dropbox.com/u/27736599/wpilib%203.png
https://dl.dropbox.com/u/27736599/wpilib%204.png
The FRC Control System guide has instructions for installing all of the necessary software (for all 3 languages) and has a few actual pictures of how the different electrical components are wired together.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 27-09-2012, 13:34
TeraViks's Avatar
AKA: Brian Induni
This is fantastic! Thank you so much... And you're a one year old team??!?! Wow, I want you on my team!
Brian
The TeraViks
Unread 27-09-2012, 14:17
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
There is a known issue with this diagram. The power connection to the wireless AP/Bridge should come not from the 12V source on the PDB but through the 12V->5V DC-DC converter. The input to the converter connects to the PDB as shown (in the dedicated 12V radio connector) and the output goes to the AP.
This assumes that you are using the standard KOP radio with a 5V input.
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 27-09-2012, 17:43
F22Rapture's Avatar
AKA: Daniel A
Well, *my* rookie year is 2012, we're actually a 2 year old team
But thanks, I'm Captain this year and half of the technical people from last year graduated (we had perhaps 10 people last year) so the hours of research I've been doing for documentation and training materials should come in handy with the new recruits.
@fever that's correct, but I didn't actually make the diagram. The Control System documentation should point that out, though.
- Wernher von Braun
Unread 27-09-2012, 19:20
TeraViks's Avatar
AKA: Brian Induni
Yep, I knew there was an issue with the diagram and appreciate the follow up.
Let me ask another question RE Windriver - there are sooooo many settings in this that I have no idea what's right and wrong. Is there a "Settings 101" that can take me through these? Things like options, references, build specs, and on and on.
Brian
The TeraViks
Unread 27-09-2012, 22:11
F22Rapture's Avatar
AKA: Daniel A
Here's a more simplistic diagram that shows the power switch -- https://dl.dropbox.com/u/27736599/Untitled.png
- Wernher von Braun
