Go to Post Never allow your students to get away with an answer that amounts to "because it's better". Have them prove it to the best of their ability, and when they're wrong, ask them to figure out why they're wrong. - Tom Line [more]
Unread 27-09-2012, 22:57
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: Is it possible to control a Jaguar with a potentiometer?
Do you have access to a Vex controller? Small and portable, remote RC control.
Unread 28-09-2012, 00:50
dtengineering's Avatar
AKA: Jason Brett
Originally Posted by DonRotolo View Post
A 556 also is a one chip solution. For me, a non-programmed solution is almost always superior to one needing programming. (Not that I dislike programming, it just seems like overkill)
Just like Ham radio operators, robot people are cheapskates. Thus the attraction of building a solution for $4 to avoid spending $25.
True, but the PIC wouldn't need external capacitors or resistors.... well, other than the pot.
But I gotta admit... the 556 even with the resistors and the caps would be slightly cheaper than the PIC... much cheaper if you didn't already have some programming hardware around.
I've used both 555's and microcontrollers in projects... I tend to like the microcontroller route because when I screw something up I can usually fix it by upgrading the software. (Why, yes. I do use Windows, why do you ask?)
Jason
Unread 28-09-2012, 01:10
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
If it were me I'd just use BDC-Comm and build a CAN to Serial Cable and a CAN terminator and use a laptop (or netbook with a USB to serial adapter).
Then again, I did write a paper on doing such so my opinion is kinda biased?
But really, all one needs is a laptop (with windows and serial means ^ ), a junked serial cable, two RJ12 (or an RJ 12 and an RJ 11), and a 100 ohm resistor. That could be built for say, $5 (or less if you already have CAN parts to your disposal). It's also pretty easy if you know how to use a multimeter and how to solder. The one I built to make my paper took like 10 minutes to make, and that was with pausing to snap pictures.
Unread 28-09-2012, 09:22
anthonyttu anthonyttu is offline
Texas Instruments Engineer
AKA: Master Chief
FRC #5417 (Eagle Robotics)
anthonyttu has a spectacular aura aboutanthonyttu has a spectacular aura about
My quick calculations for somebody to buy the resistors, capacitor and 555 would be $6.30
TI's launch pad $4.30
Laptop CAN method $1.80 (assuming you have a computer)
RC Tx/Rx $36.50 (wireless method for "safe testing")
Jumper wires $0.12
PS you only "need" the terminator for high baud rates. Not critical for testing
Unread 28-09-2012, 10:11
Jumper wires $0.12
You left one out:
RS-232 method: $0.10 for a diode.
Unread 28-09-2012, 10:16
ratdude747's Avatar
AKA: Larry Bolan
Yeah, but as cheap as (and common) as 100 ohm resistors are, why not?
Maybe they changed the firmware (or its a gray jag specific issue), but I somehow I remember back in 2011 (the last time I worked hands on with jags directly) a missing terminator would knock out the last jag in the string (it happened before); the last jag became the terminator. In the case of a solo jag, that meant that the jag wouldn't work at all.
Unread 28-09-2012, 11:54
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Here is a kit you can teach the kids about PWM at Jameco
http://www.jameco.com/webapp/wcs/sto...0001_120539_-1
The link has a funny video that is pretty good.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 28-09-2012, 12:19
AKA: Master Chief
The grey Jags and the black Jags dont have the same hardware inside them. When TI purchased Luminary Micro (the creator of the grey Jag) they changed a lot more then software.
