Go to Post 610 is an all boys school, and we were surprised to see our pit and robot neatly decorated with hot pink boas and flowers upon arrival this morning. - Mr. Lim [more]
Unread 14-01-2003, 06:35
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Extruding BMP. Is it Possible?
Last night we were working on the animation some and we're trying to get a 3-d model of Indiana, which would take a very very long time to draw by hand.... so we tried getting a bmp. file of a picture of it, and extruding it, but we couldn't even load it into Max or Inventor. Does anyone know how to do this? Thanks!
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 14-01-2003, 07:13
Soukup's Avatar
Soukup Soukup is offline
Animation Guru
AKA: David Soukup
Soukup is on a distinguished road
If you tried to import the Bmp, max doesn't do it. But I think I may be able to help you. Taking your bmp, in phoyshop completely convert the entire thing to black/white. Then completely color indiana in black and color the outside border (ohio, Michigan, Illinois) in white. In max you'll have two options. Go into the material editor and select maps and then select bumb. Import that map of indiana and then assign it to a box. Jack the settings up however you need to. You could also do this with a displace map or even a displace modifier but I'm so sure about the results.
If Indiana becomes indented inwrd then just swith the colors from white to black n your bmp. Hope that helped.
soukupd_gv@hotmail.com
Team 74 Alumni
2003 Great Lakes, Midwest, and West Michigan Regional Animation Award Winner
Unread 19-01-2003, 11:08
VanWEric VanWEric is offline
#0250 (Dynamos)
VanWEric is an unknown quantity at this point
are you looking to convert a topo map? if so, follow TEAM_74's advice. If you are looking for a 2d map, then put the image on a plane, and check the box that says something like display in view port. it should pop up in perspective. Then use the line tool to trace the border.
Unread 19-01-2003, 13:35
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
You can also use the displacement tool.
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 19-01-2003, 21:17
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
BMP
You can insert the bmp into autocad as an image, then type "sketch" or something like that into the command thingy (i've had limited training in AutoCAD, but i've seen it done). Then you can sketch around the picture and extrude that. My CAD teacher uses it all the time to remake maps or logos in AutoCAD.
Purdue Alumni
Cummins, Inc.
Extruding Lines Jim Giacchi Inventor 7 21-08-2002 17:30
