Go to Post There's a fine line between idolizing someone and stalking! - Jay H 237 [more]
Unread 28-09-2012, 16:10
carl.nartia carl.nartia is offline
FTC #4899
carl.nartia is an unknown quantity at this point
[FTC]: I'm irritated.
My team doesn't have any guide into what our arm design would be for "Ring It Up". All we can do now is try to make designs manually on paper, taking this year's FTC parts and putting it into our manual designs. All I'm asking is, is there any design program that takes the FTC parts and put it to use? A design program that is FREE?
Unread 28-09-2012, 16:21
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: [FTC]: I'm irritated.
It sounds like you're looking for a CAD program. Autodesk inventor, and the Tetrix part library, can be accessed through students.autodesk.com
Unread 28-09-2012, 16:46
FTC #4899
Thank you, I'll get to that ASAP.
Unread 28-09-2012, 16:49
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
FTC teams are also given licenses of Creo, another CAD package. Inventor is probably easier to use, though.
--Madison--
...down at the Ozdust!
Unread 28-09-2012, 18:51
gotrobot?'s Avatar
gotrobot? gotrobot? is offline
Head Coach
FTC #5037 (got robot?)
gotrobot? is a name known to allgotrobot? is a name known to allgotrobot? is a name known to allgotrobot? is a name known to allgotrobot? is a name known to allgotrobot? is a name known to all
Carl - As irritated and frustrated as you may be now you'll probably find yourself equally frustrated with the cold, bracing jump into CAD. I suggest you take a two-prong approach: have your team get up to speed with CAD but while that's happening do some research and study real-world arm/lifting mechanisms from industry. Then do a brainstorm and see if there are ideas worth combining and prototyping. Stay away from the TETRIX kit for now and just build 2D and 3D scale models with cardboard, push pins, and tape. There's a lot of learning from this approach and it will save your team lot of trial and error once the engineers move to the TETRIX platform.
2014-15 Cascade Effect: World Championship Inspire Finalist
www.facebook.com/gotrobot
Unread 29-09-2012, 10:18
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
When you are first starting in CAD it is a good idea to look at models that have come before. Luckily Pitsco uses SolidWorks and I was able to create "Mantis" with Tetrix parts.
If you are looking for SolidWorks CAD modeling go to www.solidworks.com/studentsponsorship and register to get your team SolidWorks.
Then go to http://blogs.solidworks.com/teacher/...challange.html to download Mantis and learn how to add a file folder in SolidWorks so you have all your library parts directly in SolidWorks - just easier. Review the assembly structure. A good assembly is broken down into smaller subassembies.
Marie
Unread 01-10-2012, 15:26
FTC #4899
I'm downloading the free AutoCAD program. How do I get the Tetrix parts in the AutoCAD?
Unread 01-10-2012, 15:29
FTC #4899
Marie
Where do I register my team once I click on the 1st link?
Unread 01-10-2012, 18:26
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Carl: Simplify your robot. Massively. Now.
Do it.
If you're frustrated already, you're in for even more pain. CAD will help, but it's not a silver bullet. Simplify things down to where they're manageable without CAD under nominal stress. This game doesn't NEED any one specific design to be ridiculously successful.
GitHub
