| Thread Tools |
Rating:
Display Modes |
Kinect
Hi,
I have been trying to setup the kinect, but the driver station is not recognizing it. I have followed the official tutorial exactly, three times now. Are there more recent things i am missing? I am connected directly to the crio with an ethernet and my laptop and the kinect is hooked up to the laptop. |
Re: Kinect
Although I can't be sure exactly of your problem, this sounds very similar to something that happened to us when we were first beta testing the Kinect. (http://team1912.com/beta%20testing/ktask3.html) Perhaps this of some of our other Kinect documentation at http://team1912.com/beta_testing.html can help you in some way.
Re: Kinect
The latest version of the "Getting Started with Microsoft Kinect for FRC" document is dated March 1st, 2012. Is that the version you are using? It has 3 pages of troubleshooting tips. Have you tried those?
Re: Kinect
Remember to use the 1.0 drivers, the 1.5 drivers don't work with the FIRST software.
The kinect also needs to be plugged into a *separate* computer from the driver station. |
Re: Kinect
Not true. Why did you say this?
Re: Kinect
Re: Kinect
I have a Classmate running the Kinect Server in my hands now. The problem with Classmates is that the response was very slow. If that's what was meant. Last edited by Mark McLeod : 30-09-2012 at 19:34. |
#8
Re: Kinect
Also, the tutorial I am reading is dated from 2011. I will be bringing a separate laptop with me tomorrow to try it with a lot better processor. |
#9
Re: Kinect
Here is the Kinect SDK v1.0.0.45 needed by the FRC Kinect Server:
http://www.microsoft.com/en-us/kinec...elop/beta.aspx The link came from the installation directions here: http://firstforge.wpi.edu/sf/sfmain/...=1349096485699 which should be the document you are following. Last edited by Mark McLeod : 01-10-2012 at 09:17. |
#10
Re: Kinect
Do you remember where you got this tutorial from 2011? What's the exact date?
#11
Re: Kinect
The IP address for the Kinect Kiosk (though this may just be the default and changeable, I'm not sure) via the Kinect Starter guide is:
In any case, while it may be possible to change things around to test it, it would be highly recommended to keep your setup as close to the official field specifications as possible to prevent any hidden problems. Last edited by F22Rapture : 01-10-2012 at 11:27. |
#12
Re: Kinect
Nothing unusual with the two Kiosk IP addresses. Those are correct.
All that means is that the netmask must be 255.0.0.0 for the Classmate (10.42.28.5) to talk to the Kiosk (10.0.100.15). How did you think the Driver Station (10.te.am.5) successfully talks to FMS (10.0.100.x)? In any case, the Kiosk isn't part of getting the Kinect working with the Driver Station. It's a whole separate thing. The Kiosk is simply a second PC that repeats what the Driver Station is producing. The Kinect cannot be connected directly to a Kiosk. That's why the Kiosk isn't even mentioned in the Getting Started with Microsoft Kinect for FRC document. Last edited by Mark McLeod : 01-10-2012 at 13:02. |
#13
Re: Kinect
Ah, I see what you're getting at. So the Kiosk is just a repeater to get the information from the Kinect station to the Driver station without doing anything to it? I was under the impression it was necessary to the FRC side of things.
For the record, I stand by my statement that teams should keep the testing environment as close to the official environment as possible, and that includes making sure the Kinect works properly on a second computer via the Kiosk. For consistency's sake, it might be best to stick to the more official layout, though I thank you for pointing out that it is possible otherwise. |
#14
Re: Kinect
Stop, halt, pause, wait. (it's a line from a play)
You have it quite mixed up. This is the way it must be, for the field or at home. There are not different cases. Read the documentation: Getting Started with Microsoft Kinect for FRC In particular see page 4, step 3: 3. Plug your Microsoft Kinect into your Driver Station laptop.------
It is NOT possible otherwise. Quote:
#15
Re: Kinect
Ok, so it's the Kinect Server, not the Kinect Kiosk, which reads the Kinect data... the kinect kiosk must be running on a separate computer, however, it is the server which handles the kinect and that runs on the classmate, and the kiosk only outputs the data from the server?
I probably got the Kiosk and Server confused, then. |
