Go to Post Sometimes it is more appropriate for an individual to listen than it is for him to speak. - JVN [more]
Unread 28-09-2012, 20:02
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Helical Boring G-Code Generator
Plus, as long as the G-code is written correctly, the machine does what it needs to, behind safety covers. In theory, so long as someone can clamp the workpiece, one can operate it from another state.
Some High School students understand safety and can follow complex instructions.
Unread 28-09-2012, 22:03
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
I am an student on Team 3647; at our sponsor machine shop I am allowed to run CNC Mill, Bridgeports, Lathe, CNC laser, anything else in the shop myself. However this is a community shop where you pay a membership fee and then have access the tools, provided you can demonstrate at least basic knowledge on the more complex machine tools.
However I am the only student on the team that is allowed to use the CNC hardware, having students run CNC machines can be a tricky subject as there is a lot that can go wrong and you have to very careful and go though every step in the process correctly.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 02-11-2012, 19:43
zcoops97 zcoops97 is offline
AKA: Zach Cooper
FRC #0340 (G.R.R.)
zcoops97 has a spectacular aura aboutzcoops97 has a spectacular aura about
At GRR, we recently realized our ~30 year old bridgeport with prototrak plus had cnc capabilities, and running the cnc is nothing new. We can generate programs on the DRO manually, and it is operated the same way as the g-codes we input into the DRO. You press the button and it makes it go. Learning how to operate the dials and cranks was harder than learning to generate programs on our bridgeport
