Go to Post Valentine's day, who has time for Valentine's day?????? I have code to write!! - paulcd2000 [more]
Unread 28-09-2012, 22:16
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Robot wireless bridge.
Hello all,
We have two of the dlink KOP routers and are trying to set them up so that one is on the robot and the other is a bridge that is plugged in to the DS laptop.
We have tried looking at FIRST docs and configuring the radio on the robot to Bridge mode and the radio connected to the DS laptop to AP mode but it doesn't seem to work.
Any suggestions?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 28-09-2012, 22:22
shawnz shawnz is offline
Flamewar Initiator
FRC #0907 (E. Y. Cybernetics)
shawnz will become famous soon enough
Re: Robot wireless bridge.
On the web interface of the D-Link serving as the Access Point, open Network Settings and change Access Point IP Address to 10.xx.yy.4, and leave Default Gateway blank. This will mimic the configuration of the WRT610N from previous years. Although, why not use the laptop's wireless adapter and set the robot's bridge to AP mode instead?
Unread 28-09-2012, 22:29
Mk.32's Avatar
AKA: Mark
Originally Posted by shawnz View Post
On the web interface of the D-Link serving as the Access Point, open Network Settings and change Access Point IP Address to 10.xx.yy.4, and leave Default Gateway blank. This will mimic the configuration of the WRT610N from previous years. Although, why not use the laptop's wireless adapter?
We just tried this and it didn't seem to work...
We would like the laptop to be hooked up to the wifi network so we have internet. Also the router to router connection seems stronger.
Unread 28-09-2012, 22:35
Flamewar Initiator
What are the symptoms of "doesn't work"? What LEDs are lit on each D-Link?
Unread 28-09-2012, 22:36
Mk.32's Avatar
AKA: Mark
Both routers have there enternet ports lighted and flashing really fast, the AP router has the blue light flashing, the bridge router has the orange light fashing.
Unread 28-09-2012, 22:44
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
You should be able to configure one Dlink as a access point, and the other as a bridge. The bridge would go on the robot, and you would connect your programming computer and/or DS to the Dlink configured as an access point. But you already know that...
Instead of using the FIRST configuration for the bridge, look up the manual for the version router you have (update firmware if needed! It helps!), and use the Dlink instructions for joining a bridge to an existing network (The one created from the Access Point Dlink). I haven't tested this out (I don't have 2 dlinks), but when we use bridges and access points, this tends to work best for us.
JAVA note: If by not working you mean "can't deploy code", then try having only one network connection: to the network where the robot is. At least last year, our team was scratching our heads, untill we found that netbeans was trying to deploy the code to a nonexistant robot on our other (school) connection.
If none of these work, shawnz's method is one of your best bets. The "laptop to access point on robot" connection should be good enough for programming, testing, and indoor demonstrations (given 802.11n wireless cards). In our case, updating the router's firmware inexplicably made a huge 5db difference, and also gave much better trip times and packet reception.
Good luck!
Unread 28-09-2012, 22:46
Flamewar Initiator
Hmm... When was the last time you have successfully used the robot? What setup were you using then?
I've had similar issues with LabVIEW also. I'm pretty sure 10.9.7.0/24 is not used by our school, so I don't know how it could possibly get confused, but... it seems to happen sometimes.
Unread 28-09-2012, 22:55
Mk.32's Avatar
AKA: Mark
When I say cannot connect, I mean I can't ping the robot with the CMD
Unread 28-09-2012, 23:08
This is a very important question to ask, especially if you need to fix something ASAP.
What can you ping? (AP, bridge, etc?) If you don't know an the IP, let Windows generate a network map for you. Once that is done, you can check to see if your bridge is even connected to your AP by checking your AP's log to see recent events (like something connecting...). If the bridge is connecting, then this is a problem with your computer. If that bridge isn't connecting, reset it and try connecting it as a bridge using Dlink's manual's instructions.
Unread 28-09-2012, 23:17
Mk.32's Avatar
AKA: Mark
We have not had the dual router setup in awhile... when we just do the robot router in AP mode i can connect to it fine with my laptop and run stuff. But we want the 2 router setup for demos/future use.
With the DS laptop we can ping the router plugged into the laptop, but not the robot/nor it's router. The two routers are not connection; so is there way to get the two router to talk to each other?
Unread 28-09-2012, 23:24
Flamewar Initiator
Are you sure the robot router is not still configured with competition settings? Maybe try running them in reverse -- use the robot d-link as the AP, and the laptop d-link as the bridge.
Unread 28-09-2012, 23:30
Mk.32's Avatar
AKA: Mark
We reset both routers and configured them as per the FRC doc... and we tried that as well to no advil...
Unread 28-09-2012, 23:37
Flamewar Initiator
Can you confirm that, when trying this, you did not use 10.36.47.1 for both devices, like it says to do in the manual, but rather gave one of the two d-links the IP address 10.36.47.4 (preferably the one connected to the laptop) instead?
Unread 28-09-2012, 23:55
Mk.32's Avatar
AKA: Mark
Yes
