Go to Post A good engineer will never stop learning. From his peers, technicians, and competitors. The field is just to vast for any one person to know it all. - Mr. Mike [more]
Unread 28-09-2012, 18:11
jbsmithtx's Avatar
jbsmithtx jbsmithtx is offline
FIRST Fanatic
AKA: Josh Smith
FRC #4206 (RoboVikes)
jbsmithtx is a jewel in the roughjbsmithtx is a jewel in the roughjbsmithtx is a jewel in the rough
Re: KOP Drivetrain vs Voucher
As much as my teacher likes the whole new belt idea, I'm pretty sure we'd rather go with the voucher... Depending on the game, we would like to use mechanums this year and make our drive train. Seems like different games require different drive trains, and better maneuverability is always going to be a plus....
Unread 28-09-2012, 19:37
Andrew Lawrence
Posts: n/a
256 is going with the voucher. I've been designing a new custom drivetrain that utilizes our steel tubing, so we're super excited to be able to get the $450 to AndyMark. Maybe we'll get to use shifters!
Unsure on whether you want the voucher or Kitbot? Here's something that'll help:
Do you have a custom drivetrain that's been proven to work that you've spent a long time perfecting and carefully designing, with all the math and physics done?
If no to any of those parts, kitbot is probably a good idea. Plus, this year it's an awesome kitbot.
Unread 28-09-2012, 19:42
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Taylor View Post
KoP.
Even if we don't use the KoP on our chassis, it's good structural material to have - even if for offseason projects.
Yes, but is it really $450 worth of aluminum?
While it's not my decision, my recommendation has been for the voucher. We DO have a custom drivetrain we've been using for several years that's near perfect and works very well. But if we didn't, Kitbot is a good choice.
Unread 28-09-2012, 19:43
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
We are going with the KitBot. Although we are planning on making a custom chassis over the next few months, we may not be able to get it to a decent level before build season. It will also be interesting using belts instead of chain.
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Unread 28-09-2012, 20:02
pfreivald's Avatar
AKA: Patrick Freivald
Probably voucher -- we're still debating (and are waiting to see how our fundraising goes this weekend, because we blew our budget last year and need to make wise decisions with limited funds.)
As for the gates belting, it's awesome. We used gates belting and sprockets on our octocanum drive last year and it worked without a hitch.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 28-09-2012, 20:13
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
I'm working under the assumption it's not just aluminum. I'd think it's also the belts, sprockets, gearboxes, etc. associated with the chassis.
Hi!
Unread 28-09-2012, 20:16
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
I think this is one of the leading incentives to getting the KOP chassis this year over the voucher is the belt drive system.
1058 PVC Pirates 2016 - xxxx
Unread 28-09-2012, 20:17
Billfred's Avatar
Billfred Billfred is offline
Every medal 2815 has won* has been driven by a derivative of the kitbot.
So we'll be getting the kitbot.
*Edit: For those reading this later on, that's three gold medals and one silver in four seasons.
Unread 28-09-2012, 20:28
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
We haven't decided yet as the discussion is still going back and forth over the KOP chassis vs what to spend the voucher on. I suspect we may end up with the KOP chassis and the belt drive system for no reason other than it gives us another off the shelf option in case we want it.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 29-09-2012, 02:16
DampRobot's Avatar
Physics Major
AKA: Roger Romani
SuperNerd, a "new custom drivetrain" really doesn't sound like one that's been proven to work and you've spend a long time designing. Conciser whether or not you're making a smart decision given your own guidelines.
-Plutarch
Unread 29-09-2012, 15:00
Andrew Lawrence
Posts: n/a
More or less. I'm just saying it's usually a smart idea to know that what you are using works before using it in a build season. The kit of parts was designed by engineers, and has gone through vigorous testing, something custom you design in season may not be as effective, since it hasn't been tested much.
Unread 29-09-2012, 15:12
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
For us the decision was a hard one. We usually build kitbots, so the KoP was the reasonable choice, but we weren't enthusiastic about using belts.
We thought of using the voucher to buy all the raw materials for a chained kitbot but that proved inefficient. We ended up deciding taking the KoP and during week 1 deciding whever we want to use the belts or buy series #25 chains and sprockets.
Unread 29-09-2012, 15:18
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
We're using 1114's "Kitbot on Steroids" modification this year. Within the next month or so we should be assembling a practice chassis with a second control system so we can get some extra driver practice. There may be a few modifications next year to make it work with belts, but it should work fine.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 29-09-2012, 16:01
Andrew Lawrence
Posts: n/a
Just curious - why don't you like the belts? They are more efficient than chain, don't stretch, and require little maintenance.
Unread 29-09-2012, 18:16
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
I've always been wary of belts in drivetrains, due to the more stringent tensioning requirements. Chain is much more forgiving of a little slack, and the efficiency difference is negligible for FRC drivetrain applications.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
